Jim
I still go to work regularly not every day. This may all looks easy from your perspective, it is not. Every part needs to be fitted or I won't use it. There aren't any sloppy loose fitting parts on this machine it is right and tight. I am putting forth all I have, physical, metal and economical to maintaine my work this build and accompanying article. There hasn't been time for extracurricular activities. Davenport, my goal for completion is nearing soon if all goes well the motor will be in by the end of this weekend and running before next Friday.
I have made a new brush and spring for one of my magnetos and have it running on the bench right now. It will be run in for a few days prior to installation.
The pedal crank starter assembly appears to be working well now, between that and the brake stay two troubling problems have been resolved. Throttle cable and sliders are finished. Clutch linkage is all connected and working well including the friction washers and pivot stud on the hand lever. The clutch throw out bearing is of my own construction, after plating I finish ground the mating surfaces, when it is functioning you can't here it rolling. This will be a sweet machine to ride.
Dinner is over time to get back to work.
Joe
Joe
