  • Slojo
    Evil Twin Doctor
    • Oct 2007
    • 880
    #871
    As the photos demonstrate I have dropped the ball on some of the hardware finishes, Parkerize, cadmium, even a little chrome (three Zirk fittings) whatever I have will do for now. After the event there will be plenty of time to correct these simple issues. I plan on a run date in time for Davenport. There is original nickel plating on the N.O.S. 1916 (that is another story for another time) cable straps and the oil dripper sight window.
    Joe
    • 45OZ
      • Dec 2002
      • 270
      #872
      Joe
      YO JOE !!!! I can't see where you have dropped the ball ON ANYTHING !!! You have done more in the least amount of time than ANYONE here could. GOOD GOD Man you made all the parts from blanks, I'm amazed as always with your skill & persistant Attention to detail,
      This is a bike to be Proud of & I'm sure you are & thanks for letting us enjoy the whole process. Cook ya something soon !!!
      Oz
        • 5954
        #873
        Joe,
        When ya get to Santa Monica your drinks are on me.
          • Feb 2003
          • 5353
          #874
          Sorry I'm a little late with the rest of the pics... I have a '48 Pan that's taking up a lot of time lately!!!!
          Cory Othen
          Membership#10953
          • Slojo
            Evil Twin Doctor
            • Oct 2007
            • 880
            #875
            Back to the ole grind again.
            Apparently I can't get enough sparks. Mark is doing better today and came out to watch (B.S.) while I was sparking away. With more work over at Marks now completed preparations to build the flywheels for balancing is in process.
            First it was necessary to cut the key slots in the main shaft tapered holes. To do this a broach process is the practical procedure. I don't have this type of tooling so creativity is the most practical tool in my box. A simple old fashion bore bar with a carbide tool specially ground and inserted into the spindle of the Bridgeport. Next, set up the work piece with the crank pin at 180 degrees from the key slot and tip the head on a 6 degree angle. Now get to work, I manually broached the key slot by using the quill to stroke the key slot into the tapered bore. I have done this in the past it is not as difficult as it sounds.
            The camera was left behind in the shop tonight, no photos untill tomorrow.
            Joe
            • Slojo
              Evil Twin Doctor
              • Oct 2007
              • 880
              #876
              Joe,
              Chris,
              If I make it that far even though I am not a drinker I believe that a drink will be just fine.
              Joe
              • Slojo
                Evil Twin Doctor
                • Oct 2007
                • 880
                #877
                Oz[/QUOTE]
                Oz, How about a big plater of Lasagna?
                Speaking of food, what do you think of the swiss cheesed gear set?
                Joe
                • Slojo
                  Evil Twin Doctor
                  • Oct 2007
                  • 880
                  #878
                  With the shafts for the flywheels finished and the flywheels themselves complete it was time to assemble the wheels for balancing. They trued up with ease.
                  Chris magnafluxed and honed the rods for me and I pressed the races into the big end today. Bushings for the wrist pins will be finished tomorrow.
                  Pistons are back from the coaters both Teflon (skirts) and ceramic (tops) coating have been applied.
                  Chassis work included new washers for the rear stand, control cable internal wires run through the spiral outer cases. This was interesting as I used wire spring steel, once uncoiled it straightens out. Front brake is now adjusted, New custom brake cable ordered today from Barnett (the clutch people), they will ship tomorrow ,what great service. I will be using a simple brake lever off an early seventies H.D.. This aluminum brake lever has the mirror mount built in making things easier and less damaging to the plating on the handle bars.
                  I finished the day off with yet another trip to Sparks shop to grind the crank pin bearing cages narrower to fit my application. Originally the nuts on the three flywheel shafts and the bearing cages were used in a 900 cc iron Sportster motor.
                  Joe
                    • Feb 2003
                    • 5353
                    #879
                    Cory Othen
                    Membership#10953
                    • MJW
                      • Mar 2007
                      • 127
                      #880
                      I've never really noticed on the early motors, is there a timing mark on the flywheel? Mike
                      • Slojo
                        Evil Twin Doctor
                        • Oct 2007
                        • 880
                        #881
                        Mike
                        Good question, there were no timing marks cut in the flywheel (no access port to see the timing marks either). Timing was set by piston location measured from the top motor mount plug of the rear cylinder, the # 1 cylinder. I may mark the flywheel for advanced firing in line with the oil drain hole, the only access to the flywheel. Problem, where is the most effective firing position for this motor?
                        Joe
                        • fillibuster
                          red dog
                          • Aug 2009
                          • 934
                          #882
                          Balance and timing, who's got it? We discussed balance somewhere recently, but we never got into a general overview. I expected to read some things about bore and stroke, angle of cylinders, overall weight of rotating and recip masses, any of the many considerations for balance, but last I remembered we talked about Chiefs and Scouts.
                          Who's the teens techie? Where does one start?
                          And about the timing, ... and the fuels,...
                          Surely someone can write a bucket-full of bs on this. .. I'd farm out that bs job, slojo, but let us know what you're running, please, please.
                          • Slojo
                            Evil Twin Doctor
                            • Oct 2007
                            • 880
                            #883
                            Closing In
                            A run into the city to fix a machine and then the usual trips to suppliers.
                            McGuire spring shop for my new carb. springs, Chris the welder took care of a couple small projects, dropped the clutch lever off to be repainted after altering bends to fit and operate properly. Next to Exotic Plastic and Rubber for some rubber hose to cut and insert on the lower frame rail to cushion the gas tank mounting as originally done. I also picked up some black wrapped rubber hose that I may use for head light mounts, more on that as it progresses. Don't forget the Harley boutique for Sportster spark plugs to be used on this trip with adapters I will make.
                            Back in the shop a new leather choke for the carb. was reproduced like original. This is a back up in case I (the Gray Ghost) don't like the new teardrop black plastic choke I developed for the carb. This devise works like a constant velocity valve for the early Schebler carb's. I had to shorten the plastic choke to clear the butterfly when in full throttle operation. The carb is basically finished now.
                            The original rear stand catch doe's not fit properly, about 1/2" to close to the stand when in its retracted position. For now the easy way out was to make a new catch. This was bent from 1050 steel and will be heat treated to 45/50 Rc tomorrow.
                            Joe
                            • MJW
                              • Mar 2007
                              • 127
                              #884
                              Mike
                              Joe
                              Perhaps the new mark could be added thru the oil drain hole after some experimental tuning, I suppose the flywheel is a bit hard for a center punch, how 'bout an engraver?...Mike
                                • Feb 2003
                                • 5353
                                #885
                                Cory Othen
                                Membership#10953
