Numbers Letters Alphebet Soup Whatever
I have a long time passion with accuracy and detail motorcycle numbers. I know good from bad number jobs. It is obvious when number bosses are modified, grinding down or building up metal will always give away modifications or out right alterations. That being said these engine cases came to me with the numbers you see in the following photos and the cases were in excellent condition other than the scratches in the otherwise untouched metal surface finishes. The current polish on the cases was done in my shop from what was an original finish
In my travels some of the cases I have inspected have had numbers dashed out from the factory and another number stamped adjacent to it. I also have inspected numbers where the stamp was inverted and re-stamped over it. Transposed numbers are a problem, and were re-stamped over top of the errored first stamp. I currently know of two original paint unmolested 1913 twins with these very same problems in their numbering.
This 1914 engine case in question has not been modified. I was told that the H stood for fortruck, A three wheeler with two wheels and a basket or box of some sort in front (True or false I don't know). If no other provable explanation can be provided it is my opinion that the H prefix was stamped by an individual that was inflicted by dyslexia and you guys have busted your heads for no other reason other than to dispel a myth.
All is ok with the cases they showed no signs of repair or modification when I purchased them. The only damage was a minor crack in one motor mount hole and has already been taken care of as demonstrated earlier in this article. Relax a little and allow me to get this program rolling again. Thanks for entertaining yourselves and hanging around in my absence.
Joe 03-08-2010
Joe 03-08-2010
