Factory H-D Tools
    • 4791
    #61
    Pushrod lifter
    • 1937hd
      • Nov 2016
      • 62
      #62
      Some small assorted 20201209_203115.jpg tools.
      • 1937hd
        • Nov 2016
        • 62
        #63
        Save time and money in oil changes and flushes.You don't have to worry about stripping out oil tank plugs. 20201210_065044.jpg
        • scott379usa
          • Dec 2011
          • 11
          #64
          I would also be in for one of your Clutch Hub Pullers Mark.
          • 1937hd
            • Nov 2016
            • 62
            #65
              • 4791
              #66
              Originally posted by 1937hd View Post
              Lightweight flywheel tool, to clean up the recess for the stuffer plates.
              • 41craig
                • Nov 2010
                • 411
                #67
                It may be helpful to add a description with the pictures. Not everyone knows what all these tools are and what they are used for.
                Craig
                • 1937hd
                  • Nov 2016
                  • 62
                  #68
                  • 1937hd
                    • Nov 2016
                    • 62
                    #69
                      • 4791
                      #70
                      Here is the working end of the tool, the hole goes on the flywheel shaft, the handle turns the tool, and the cutter cleans the recess of old staking ears. The screws allow adjustment. The small through hole is for alignment of the staking punch.
                        • 4791
                        #71
                        Originally posted by badger34
                        Thanks guys! I was unaware of this tool and had previously wondered about how the recess was cut. Upon seeing the tool identified here I dug into the binder that my grandfather put together for our ST and found the tool page I posted above. I figured out the flywheel pinion hole and handle myself but wanted to see the cutting tool. In talking with my father it wasn't long after the ST was purchased through the H-D front office that he and my grandpa did the engine modification work, I would hazard a guess that grandpa brought the tool home from experimental to cut the stuffer recess.
                        All the standard cranks came with the steel "compression plates" in them from the factory. They had to be removed to install a new crankpin, hence the need for the tool. Most performance mods involved an aftermarket stuffer plate to reduce crankcase volume. It was a plate inserted between the flywheels and captive by the case halves.
                        • 1937hd
                          • Nov 2016
                          • 62
                          #72
                          • 1937hd
                            • Nov 2016
                            • 62
                            #73
                              • 4791
                              #74
                              Flywheel truing stand, 30s up type
                              • aumick10
                                • Nov 2018
                                • 467
                                #75
                                Rubone, when you say 30's up style for the crank jig, does that mean that the JD cranks do not fit in that style. I am looking to but a truing jig for JD's, and want to make sure I get the correct one.
