Factory H-D Tools
    • 4785
    #76
    Originally posted by aumick10 View Post
    Rubone, when you say 30's up style for the crank jig, does that mean that the JD cranks do not fit in that style. I am looking to but a truing jig for JD's, and want to make sure I get the correct one.
    They will fit fine, I am just referring to the time frame it was produced for, there are a couple earlier versions that do not do the later cranks due to width constraints.
    • aumick10
      • Nov 2018
      • 465
      #77
      Thanks, I have 4 motors to build for myself. You interested in selling that one? Cheers
        • 4785
        #78
        45 clutch tool, works on both '40 and earlier and '41 up clutches to remove lock nuts (and adjust spring pack spacing on the early one) DCP_3959.JPG .
        • 1937hd
          • Nov 2016
          • 62
          #79
          Panhead tool.
          • 1937hd
            • Nov 2016
            • 62
            #80
            • Architect
              • Dec 2014
              • 283
              #81
              Hey Robbie, did the MoCo have a tool for Shovelhead/Ironhead rocker shaft end caps with the slot? You got a picture of one??
              • 41craig
                • Nov 2010
                • 410
                #82
                Originally posted by 1937hd View Post
                Panhead tool.
                I have the tool that you are displaying, but mine has the spring and rubber bushing that is shown in the catalog. My question is what is the purpose of the spring and bushing? It's easy to figure what to do with the tool itself.
                Craig
                  • 4785
                  #83
                  '41 up 45 clutch hub nut wrench
                    • 4785
                    #84
                    Piston pin lock ring tool for "L" section lock rings
                      • 4785
                      #85
                        • 4785
                        #86
                        BT mainshaft starter clutch and bearing puller
                        • 41craig
                          • Nov 2010
                          • 410
                          #87
                          Ignition Timing Gage 95882-63 for gaging top dead center. CIMG1929.JPGCIMG1930.JPG
                          • 41craig
                            • Nov 2010
                            • 410
                            #88
                            Inlet Housing Nut and Crank Case Bolt Wrench 11903-X for 1929 and earlier big twins. CIMG1944.JPGCIMG1945.JPGCIMG1946.JPG
                              • 4785
                              #89
                              Crankpin and shaft nut wrenches assorted sizes.
                              • 41craig
                                • Nov 2010
                                • 410
                                #90
                                Piston Pin Pusher Tool 11910-X ( missing the handle, guide pin, and pusher collar. CIMG1954.JPGCIMG1955.JPGCIMG1969.JPG
