Factory H-D Tools
  • 1937hd
    • Nov 2016
    • 62
    #31
    • MMasa
      • 1192
      #32
      1937HD
      you want to sell that JD tool?
      mark
      Mark Masa
      www.linkcycles.com
      • 1937hd
        • Nov 2016
        • 62
        #33
        Not at this time.Just nice to have in case I need it.
          • 4785
          #34
          DCP_2568.JPGDCP_2569.JPGDCP_2570.JPG Hydra-Glide fork bushing tools...
          • painterdale
            • Oct 2013
            • 423
            #35
            I plead ignorance!
            What's the JD tool used for?
            Dale
              • 4785
              #36
              • painterdale
                • Oct 2013
                • 423
                #37
                Very interesting!
                Thanks, Robbie!
                Dale
                • 41craig
                  • Nov 2010
                  • 410
                  #38
                  [QUOTE=Rubone;n278737]Sidevalve valve spring compressor.
                  Robbie maybe you missed my question. Did you or the previous owner bend down the ends of the fork or is this a later upgrade to the valve spring compressor ?
                  Craig
                  • 41craig
                    • Nov 2010
                    • 410
                    #39
                    This is a facer for crank case bronze bushings 1929 and earlier Big Twins. It's used to face off the thick shoulder of the gear side crank case bushing after it has been pressed into case. Part # 11939-X The cutter on the tool was replaceable with Part # 11940-X.
                    Craig
                      • 4785
                      #40
                      [QUOTE=41craig;n278858]
                      Craig
                      I have two of them and they were both that way when I got them in the '70s. Not sure if it was factory or dealer done.
                        • 4785
                        #41
                        '41 up 45 transmission mainseal removing and installing tool
                        • 1937hd
                          • Nov 2016
                          • 62
                          #42
                          20201204_175919.jpg VL clutch tool
                          • 41craig
                            • Nov 2010
                            • 410
                            #43
                            Piston squaring plates for Big Twin 61" 74" 80" part # 11919-X and for 45" models part # 12655-26 CraigCIMG1938.JPGCIMG1939.JPGCIMG1940.JPG
                            • 1937hd
                              • Nov 2016
                              • 62
                              #44
                              • 1937hd
                                • Nov 2016
                                • 62
                                #45
