Factory H-D Tools
    • 4785
    image_26307.jpg First attempt at pic with new format.
    Bushing puller with guides.
    • Peter Cooke
      • Aug 2012
      • 570
      Originally posted by MMasa View Post
      I should really make another run of those clutch pullers.
      I'm in for one if you do Mark.
        • 4785
        These are a necessity if doing work on a U series engine (the hook wrench is also for V series) to be able to loosen valve covers. The early wrench is up to '38, the cover lifter is '39-'48.
        • 41craig
          • Nov 2010
          • 410
          Here is the factory Side Valve Tappet Guide Puller WL G K V and U Models.
          • 41craig
            • Nov 2010
            • 410
            This is the late style crankcase bushing and bearing puller with an addition to the bridge which makes it a whole lot easier to use. I also have the earlier style as posted above, but for me, this is a whole lot quicker and easier to use.
              • 4785
                • 2024
                No offense Robbie but the engineer that designed this tool needs an ass kicking and his license taken away. Probably the same guy who designed the 1939 4 speed.
                Jerry
                Originally posted by Rubone View Post
                • 41craig
                  • Nov 2010
                  • 410
                  Just curious Robbie. Do you have the "cheater" Extension Handle that was sold for the bar to give you more leverage? Part # 12082-XA. I was wondering about the length. I have the bar although mine is painted blue.
                  Thanks, Craig
                    • 4785
                    Thanks, Craig
                    No Craig, just the bar. Bought it at a farm sale where it was sitting with a bunch of conduit benders. Cost me a whole $2.00.
                      • 4785
                      Sidevalve valve spring compressor.
                      • 41craig
                        • Nov 2010
                        • 410
                        Robbie; Did you bend down the ends of the fork section to prevent it from slipping off of the lower spring collar or is this a later, factory upgrade to the tool? This simple tool is one of the most used tools that I have. I put a dab of grease or assembly lube on the locking lever where it contacts the tool to make it work easier.
                        • 41craig
                          • Nov 2010
                          • 410
                          #27
                          This is the springer handlebar end tap. CIMG1925.JPGCIMG1926.JPG Craig
                          • 41craig
                            • Nov 2010
                            • 410
                            #28
                            These are the taps for the intake nipples on Big Twin OHV 61" Knuckleheads and 74" Knucklehead and Panhead models. CIMG1920.JPGCIMG1921.JPGCIMG1923.JPG Craig
                              • 4785
                              #29
                              Since Servi-Car wheel pullers were recently discussed here are two, the larger diameter for '32-'36, the smaller for '37-'50. The '51 and later juice wheels use a standard automotive type. DCP_3963.JPG
                              • 1937hd
                                • Nov 2016
                                • 62
                                #30
                                This gallery has 1 photos.
