Factory H-D Tools
    • 4785
    #106
    • Tommo
      • Sep 2001
      • 1320
      #107
      While having a general clean-up I pulled out my box of HD factory tools and cleaned them all up.
      Here's some that haven't been posted before and if the word available appears that will indicate that I'm prepared to sell that particular item
      This one is available DSCF3893.JPG ​​​​​​​
      Peter Thomson, a.k.a. Tommo
      A.M.C.A. # 2777
      • Tommo
        • Sep 2001
        • 1320
        #108
        A.M.C.A. # 2777
        • Tommo
          • Sep 2001
          • 1320
          #109
          This one has me stumped.
          It has been well used and repaired but what is it for? DSCF3907.JPGDSCF3906.JPG
          A.M.C.A. # 2777
          • Tommo
            • Sep 2001
            • 1320
            #110
            A.M.C.A. # 2777
            • Tommo
              • Sep 2001
              • 1320
              #111
              Until I started this tool sort out I didn't realize that there were so many differences to the HD chain breakers.
              The top one has no part number cast on it.
              The second one has but has no hyphen between the Harley Davidson.
              The next one has the Harley Davidson name in a different font
              The last one has the threaded end with the long pin to assist with pin removal DSCF3958.JPG
              A.M.C.A. # 2777
                #112
                Dear Tommo, your well used item might be a pinion gear puller. You'd push it over the gear, give a quarter turn to lock it, then pull out the gear with that fine thread producing plenty of traction.
                  • 4785
                  #113
                  Clamp block for sidecar ball joint removal.
                  • 41craig
                    • Nov 2010
                    • 410
                    #114
                    CIMG2002.JPGCIMG2003.JPGCIMG2036.JPG Big Twin Countershaft Sprocket Lock Nut Wrench Old Part # 12023-X New Part # 94660-25 CIMG2001.JPG
                      • 4785
                      #115
                      Miscellaneous piston ring compressors. The one with the ears is K-Model, there is another one without the ears for Sportster. The cast iron ones are BT and 45 DCP_4547.JPGDCP_4548.JPG
                        • 4785
                        #116
                        Pin wrench for left main bearing seal retainer for '55-'68.
