1965 Panhead Book Project
  • upsrod
    • Feb 2010
    • 320
    #136
    The L bracket and rubber mount a '68 and up, if mounted to the top tree, no one will know after the bike is together and it won't break!
    • paddy
      • Apr 2014
      • 219
      #137
      GOOD POINT UPS!!!!!!!!!! Its gonna stay !!!!
      • pjs
        • Nov 2009
        • 14
        #138
        Great pics of the horn bracket and board. Thanks. Still looking for input on placement of the flasher. Next to the green light dome could be the answer, what's the rest of the 65 owners have to say? Thanks.
        • K. Felt
          • Mar 2014
          • 42
          #139
          [ATTACH=CONFIG]14446[/ATTACH?
          Small screw is where I think flasher is mounted.
          • K. Felt
            • Mar 2014
            • 42
            #140
            Sorry, have no idea why the pic of flasher mount screw is upside down.
            • paddy
              • Apr 2014
              • 219
              #141
              K, I was reading on the 65 wiring thread under panhead .A member Panz sent steve little a diagram and instructions on the installation of signal diectionals.take a look but believe it or not it says to tape the flasher to the cable or harness see figure 2.I myself have not seen that screw on the panel by the green light.Do you happen to have a slot on both sides on the panels just below the lower side mounting holes as described in the same instructions(figure 2 ri it is a 1/2 inch slot)?????
              • Underdoggie
                • Mar 2009
                • 100
                #142
                The flasher is shown in the bottom of the two pictures I posted. It is small and rectangular like a main breaker and has a rubber sleeve around it. By the way, my spotlight switch is not in the position it was originally. I moved it down the handlebar closer so the wire loom would be hidden under the cover. Normally they are about half way up the bar on the right side.
                John Underwood
                AMCA#14400
                Central Illinois
                • paddy
                  • Apr 2014
                  • 219
                  #143
                  John.gotcha on the local of the spotlight switch..Do you have the slot that the instructions refer too???
                  • pjs
                    • Nov 2009
                    • 14
                    #144
                    John
                    Is that it hanging at the very bottom of the pic?
                    • Underdoggie
                      • Mar 2009
                      • 100
                      #145
                      Originally posted by pjs View Post
                      John
                      its almost in the center of the bottom picture just above the horn and over slightly. The wire loom at the bottom is for the headlight.
                      John Underwood
                      AMCA#14400
                      Central Illinois
                      • upsrod
                        • Feb 2010
                        • 320
                        #146
                        John, doesn't your flasher clip into a holder (like the 3 clips holding the breakers to the rear fender of your Superglide) that is held to the headlight housing by the 8/32 screw referenced in the earlier posts?
                          • 8248
                          #147
                          Wish I could add some real substance to this discussion Folks,
                          But in all honesty, I am compelled to add confusion.
                          A fellow who worked at the Factory during the period visited occasionally (and once returned with Willie G. "himself", and John D., who didn't bother to come in...) told me when I asked about the indicator lamp colors, that much of the final assembly of such details was left to the dealerships.
                          Sometimes there is no absolute *AMCA* "correct" assembly.
                          PS: (Can you all hear the Divas gasp?)
                          • K. Felt
                            • Mar 2014
                            • 42
                            #148
                            paddy, saw the wiring diagram like you suggested...tape! I thought those instructions were for people adding directionals after the fact...not for factory ones. My '65 has the directional switch mounted on the right handlebar between the throttle grip and brake lever clamp and under the starter button with wires running through the bar which I thought was factory stock. It shows the switch just like mine in the same position in the original '65 riders handbook. The first time I disassembled the headlight housing I noticed the small hole on left rear housing...(the one in my picture). It had a ground wire attached to it. Could not figure out what it was for. Then I saw a beat up old housing at a swap meet with the same hole but it had the square or rectangular flasher mounted to it. Then I saw another '65 somewhere with the same hole so I figured that is how the factory must have done it. Now I don't know. Just using an automotive 12 volt flasher mounted somewhere inside housing (can't remember where).
                            As far as the slots on the panels below the lower side mounting holes...been so long since it has been apart I can't remember if they are there or not. Keith
                            • paddy
                              • Apr 2014
                              • 219
                              #149
                              K welcome to my world.I try to read and ask questions about my 65.Because I have seen certain things that are not the same on every bike.And all those guys said "It was like that from the factory"There quite a few members that are pretty well versed in this year machine and like mr cotten pointed out there were more than just the factoy had their hands involved . I scratch my head somtimes. I have been told and I have seen the stem mirrors with the curve.It is even in the broshure.Yet I have seen pictures of people with their brand new bikes with 66 style mirrors and the picture i beleive dated sept of 65.And the tappet screen is another wonder.Some got it some don't. i give up.I was told that turn signals were a option in 65 and I have seen them without the signal lights.I guess I will just tape mine ,As I dont see myself coming across that type of bracket anytime soon.If you do give me a shout and let me know if you have that slot.I am wondering what that slot was for??? Thanks Paddy
                              • K. Felt
                                • Mar 2014
                                • 42
                                #150
                                Paddy, was just reading the directional installation instructions again and the "notches" or slots are for the left and right directional light wires to pass through. Never knew that. Most if not all (including mine) of the ones I've seen just run from the bulb housing up and under the bottom of the headlight housing next to the forks. I always thought that was a little messy. Just not sure if I want to start cutting / grinding a good headlight housing just to clean up a few wires. If I had a choice I would do what you said with the flasher and tape or mount it somewhere inside housing and avoid drilling a hole in the housing.
                                What you and others are saying about differences in mirrors and other parts for a particular year is so true I have found. I have a low number bike and have the mirror stems mounted right into the clutch and brake lever clamps for example. I have read they are supposed to be clamped on. Could have been changed but looks a lot cleaner in my opinion and I consider it correct. Paint is another issue...factory photos show the stripe on the tank a lot closer to the bottom of the emblem than some original paint '65's I have seen. ??? Keith
