VL Trans rebuild
  • 26fhead
    replied
    Steve,
    What is the correct way to assemble the clutch?
    Thanks Steve
  • Steve Slocombe
    replied
    We've all been there, and also chosen the wrong 50/50 way of assembling the VL clutch. There were no shop manuals on the VLs so a lot was left to the experience of the mechanics. Shop Dope 92 of 14 Dec 1931 says just 24 men will be instructed this winter at the Mechanics School starting at the factory 11 Jan 1932. Where room and board could be arranged for $9 a week...
  • Guest
    Guest replied
    Well Grumpa I did see that in the book but that didn’t stop me from making other mistakes. I finally replaced the main shaft which I should have done in the begining. Now everything is turning smoothly. I’m anxious to see how it shifts once I get all that linkage hooked up. Happy New Year!
  • Grumpa
    replied
    I had a 50-50 shot at getting it right, story of my life lmao IMG_2407.JPG wrong.jpg Hopefully this will help someone else out.IMG_2408 correct.jpg
  • Grumpa
    replied
    Originally posted by dustydog View Post
    I have mine almost finished …
    Well here's a tip to pass on that I'm hopefully not too late in posting Dusty; this just in from the one step forward two steps back department. On installation I was having trouble with the shifter tower IMG_2401.jpg It seems I failed to read Steve's note (page 98 4th edition or 13-7 in the 6th) "...point rather than flat towards the front...or shifter will be out 30 degrees..." Trans comp.jpg
  • Guest
    Guest replied
    Thanks Grumpa for sharing your build. I have mine almost finished and you were very helpful. Thanks again.
  • Steve Slocombe
    replied
    Nice job Grumpa and it's always good to find a box with the cast ear intact. The VL three speed gearbox is a little old fashioned, dating back to 1915, but it sure is a robust, well designed, and long lasting unit. Don't forget to mark on the calendar that it will need more work in about 50 years time.
  • Grumpa
    replied
    At long last this tranny is together, before and after pics: IMG_1883 (1).jpgIMG_2378.jpgIMG_1884.jpgIMG_2379.jpg The clutch shell run out ended up being +/- .010", at least I know what I have to replace. Made mistakes, learned a lot and basically had a blast.
  • Grumpa
    replied
    Okay after eliminating all variables, it came down to the clutch hub/shell. The shell itself is flat within <.001" yet it's still off because of the hub. I got it dialed down to +/- .017 (.034 total) which I'm not happy with but I will deal IMG_2369.jpg. Better than the .080" runout before.
  • Grumpa
    replied
    Installed a new bushing and used a parallel hone IMG_2347.jpgIMG_2348.jpgIMG_2350.jpg shell runout check tomorrow, stay tuned. Pretty much has to be better than it was before. I actually dialed in the shell closer than the above post, down to +/- .008" but it went from being 180 degrees high and low to 90 degrees, at which point I stopped having no idea how to deal with it.
  • Grumpa
    replied
    Pretty sure the problem was that I reamed/honed the main drive gear bushing incorrectly. While I wait for a new main gear bushing to arrive I checked the (verified straight) mainshaft and the runout of the clutch shell and came out with +/- .010: IMG_2340.jpg Just the shaft and shell relation at this point but here's a visual of it with a height gauge: High point IMG_2341.jpg low point IMG_2343.jpg chain area high point IMG_2344.jpg and low point IMG_2345.jpg I can live with it so far.
  • Grumpa
    replied
    Update, I tore it back down and replaced both bearings. I added the brass seals per Steve's suggestion (post #52). Assembled with new bearings IMG_2323.jpg and checked IMG_2324.jpg and it's a bit better, only +/- .002 now. Knowing the shaft is good (within .0005") I moved the slider gear off the main. Checked again and the shaft was straight. So I have a good idea where the issue is. Pass me that hammer
  • Grumpa
    replied
    Originally posted by Peter Cooke View Post
    I not sure you should have a clearance fit between the main drive gear and the large bearing. I measured my main drive gear and got 1.575" OD and the ID of my (6208-2RS) bearing is 1.574". That would seem about right for a very light interference fit.
    I agree, my memory failed me I believe and that's my only excuse. It wasn't a clearance fit at all it was a very light interference fit as you describe. In hindsight I was probably just being OCD on not wanting the main drive gear to spin inside of the bearing. More likely the bearing was cocked slightly.
  • Grumpa
    replied
    Originally posted by Robert Luland View Post
    Anyone have a straight mainshaft available?
    https://www.thegoodoldmotorcyclepart...Mainshaft-1196
    Like I was saying in post #69 the mainshaft I bought checked out to be straight. The keyways leave something to be desired (post #46) but all things considered a great product and I recommend you as a provider. The problem seems to be in how I installed the 208PP sealed bearing, I'm guessing it was cocked slightly. Removed and am installing a different one to eliminate that variable. At this point I'm considering changing from heating the case to freezing the bearing.
  • Peter Cooke
    replied
    Originally posted by Grumpa View Post
    I did note on assembly that there was a clearance fit between the gear and the bearing and consequently I mounted the gear with red Loc tight. That might be the where the offset happened.
