VL Trans rebuild
  • Steve Slocombe
    replied
    The 1931-36 main drive gear has deeper teeth than the 1925-30 type, plus it has a bushing inside to go over the 1931 unstepped mainshaft. The late drive gears are getting hard to find, so many are using the earlier type which seems strong enough. When using the earlier gear on the later mainshaft, you need to bore out the gear, which is very hard, or thin down the 1931 bronze main gear bushing.
  • Grumpa
    replied
    Confirmed the stack-up works:IMG_1977.jpgIMG_1976.jpgIMG_1975.jpgIMG_1974.jpg
  • Jim
    replied
    I'll be the first one to say, I don't know enough about these transmissions to give you any "help" on which could be the correct gear. Although, I think you were correct in that someone had left out the 2339-25 spacing collar so the sprocket was rubbing directly on the case causing the "friction" and slowing you down.
    In fact... I have a JD Transmission in my 1936VLH! HAHA!! It goes down the road fine, so... what can I say? HAHA!!
    GOOD LUCK!
  • Grumpa
    replied
    So I scrounged and in another box of parts I came across what I think is the correct main drive gear, but I defer to you to confirm or deny my assumption:IMG_1969.jpg IMG_1970.jpgIMG_1971.jpgIMG_1972.jpgIMG_1973.jpg
  • Grumpa
    replied
    To continue, the Al Qaeda infiltrators who rebuilt this tranny used the earlier mainshaft and drive gear: IMG_1967.jpg
  • Grumpa
    replied
    Okay so moving on here's the back story on this tranny: It was removed from a 1934 VD and it was a project bike when I got it probably 25 or 30 years ago. When I got it running it would go down the street and then it would seize up; kept running but it was like the brakes were on. Traced it down to some issue with the tranny, put in a stand in tranny and this tranny has been on the shelf since. Finally got a chance to go through it now. Pretty sure it seized when it warmed up because the last guy who was in it left out the 2339-25 spacing collar so the sprocket was rubbing directly on the case. IMG_1937.jpgIMG_1939.jpgIMG_1940.jpg
  • Grumpa
    replied
    Originally posted by Jim View Post
    Whenever I 'repair' anything, I always ask myself "How much" will I actually ride this machine. It took 80+ years and thousands of miles to look like that. So... how many miles will you actually ride it after you're finished?
    I would use that gear as long as you can't see any "cracks" down near the base of ANY tooth. IF you see any cracks, then, no I would not use it. Maybe use a dye penetrate on the gear to search for hidden cracks?
    Thank you Jim and RCamp, exactly the feedback I was looking for. Yeah I was balancing the "perfect restoration" i.e. trying to locate all NOS parts and truly respect history and the machine vs reality. My theory comes down on doing my best to have original OEM parts but I'm not above using sealed bearings on this tranny. So yes, I'll probably use this gear unless I find a NOS one at an affordable price. I just didn't know how much I could clean up the gears and what to look for. I didn't think of a dye-pen inspection. I should have done that before my clean-up because sanding can smear metal and hide cracks.
  • Jim
    replied
    Whenever I 'repair' anything, I always ask myself "How much" will I actually ride this machine. It took 80+ years and thousands of miles to look like that. So... how many miles will you actually ride it after you're finished? Just a thought. Good luck with the machine.
    OH... so my answer would be, YES I would use that gear as long as you can't see any "cracks" down near the base of ANY tooth. IF you see any cracks, then, no I would not use it. Maybe use a dye penetrate on the gear to search for hidden cracks?
  • RCamp
    replied
    Looks like it cleaned up pretty good, I'd run it
  • Grumpa
    started a topic VL Trans rebuild
    VL Trans rebuild
    Okay I could use a little wisdom here. Rebuilding a VL transmission and not sure where to draw the line. I took the liberty of cleaning up my 2298-15 slider gear, knocking off the burrs and smoothing out the chips. IMG_1961.jpgIMG_1962.jpgIMG_1965.jpgIMG_1966.jpg Would you run this gear?
