Grumpa,
Yes, I was referring to posts 29-33, thanks for the info! Sounds like my antique South Bend lathe is not the tool for the job, I’ll see if the big Jet we have at work will get the job done.
For such a “simple” gearbox, it appears to have challenged more than a handful of us. In my case, due to the upgrade of using sealed bearings that do not maintain the main shaft and output shaft offsets.
VL Trans rebuild
NCriding,Originally posted by NCriding View PostWould you please provide the part number of the seal you installed in the output shaft? To cut the recess, did you just insert an expanding collete in the bronze bushing?
I believe I used seal 12022 if you're referring to the seal added in post #29 - #33. Modifying the gear was alas, beyond the capacity of my little benchtop so I had a buddy at work do the deed. He noted that the gear was "hard as fuk" and whatever he did ended up with a pretty loose fit to the seal
Glad you enjoyed the thread - like I might have mentioned earlier; it takes an entire village to raise this idiot.
Thank you! Enjoyed reading your trans build story and learned a lot from it.
Harley-Davidson part #12035B seal for output shaft. Works well on 31 up
Grumpa,
Thanks!
NC riding
Hi Ray,
I sent you a PM a couple of months back. Just wondering if it got to you?
Peter
That’s usually the problem when they won’t go into gear without grinding. Replace thrust washer with thinner one or grind .005 thousandth off.
This is a great thread! Lots of hidden tips for the VL trans. I recently put new sealed bearings in my transmission and also replaced the clutch plates but I'm having a hard time shifting in to first or second from an idle. Once the bike is moving the rest of the up/down shifting is fine. When at an idle though, trying to get into first requires a lot of moving the bike back and forth and double clutching to finally get it to go without grinding. I notice that even after adjusting the clutch that the bike is still noticeably harder to push when the clutch has been released than when the bike is in neutral and the clutch engaged. From reading this post I'm thinking my thrust washer is too thick and causing some additional drag?
970D4E2F-B38D-4D25-BBB2-4977F88012B8.jpgtook me a while to figure out how to make this work
Bottom left and right are homade stamps. On retainer is stamped washer. I just finished another VL Tranny today,same issues. Hope this helps. Ray
Right, got it now thanks. My g'box came in pieces so I never had the original bearing to compare to the sealed one. I went back and looked at Grumpa's photo in post #50 and you can sorta see how the inner sits off centre to the outer.
I'd be interested in the details of your new washer if your able to share it? I'm sure others would as well.
It’s not the width that’s different. The original bearing race is not centered,there is some offset If you measure from inner race to outside face of threaded retainer on original vrs installed 6304 bearing you will see the difference
Dear All, don't forget that sealed bearings moves the gearbox mainshaft relative to the clutch, so you will probably need a new 2500-19 thrust washer under the clutch hub bearing. Harley made this in 0.006" size increments so must have thought it important. Too thin allows for wobbly clutch, two thick binds the clutch drum and drags the clutch after rebuild, which is even more annoying.
