Powerplus or Bust, Eh?
  • Shaky Jake
    Ol' Poop
    • Jan 2013
    • 261
    #796
    In addition to the classy T Shirts, Team Kelly's Heroes & Speed of Smell Racing will be bringing along on the Cannonball some of these nifty frisbees. All you need is a dog with a bandana and you're one of the cool kids. Or, bring a sharpie and have all the riders sign it for the perfect wall hanger for your shop or she-shed. Priced at a measly seven bucks. Cash only. No tax, no tracks.
    Kevin
    Kevin
    • nuklhd
      • Jan 2009
      • 54
      #797
      I have the shirt but i'd like to send what I could afford thru her go fund me page if you find the link.
      • Shaky Jake
        Ol' Poop
        • Jan 2013
        • 261
        #798
        Here's the link. Thank you very much sir.
        Please check the URL and try again or, alternatively, you can browse fundraisers currently receiving the most donations worldwide below.
        Kevin
        Kevin
        • Shaky Jake
          Ol' Poop
          • Jan 2013
          • 261
          #799
          While I'm posting links, here's another one. Once again, Brenda will be keeping a daily Cannonball blog. Here's the link:
          Kevin
          Kevin
          • Shaky Jake
            Ol' Poop
            • Jan 2013
            • 261
            #800
            I had a little Cannonball practice today. Patience slung her chain off. It hit the chain guard and broke the rear mount. I'll have to weld that tonight.
            Fortunately I had a spare master link along. You guys all carry one, right? This time I will safety wire the clip.
            A short walk back up the road and I got to watch a Miata run over my chain just before I got to it. No harm done and the guy gave me a lift back to my machine. His comment was "that looks like one of those Cannonball bikes!"
            Here's the weird thing. Two years ago, just a couple of weeks before the 2016 Motorcycle Cannonball, I lost my throttle linkage pivot in the exact same place. I planted Patience firmly in the weeds trying to turn around with no throttle.
            Kevin
            Kevin
            • BoschZEV
              • Jul 2012
              • 521
              #801
              The conclusion from these two incidents is clear. When practicing for the 2020 Cannonball, don't take that road.
              • Spacke2speed
                • Jul 2014
                • 59
                #802
                Kevin
                On one of my early Excelsior twin single speed motorcycles, I had a problem with it spitting out master link lock clips. Even just the fact of trying to pedal start the bike would result in the broken lock clip on the ground. It turns out that in back of the pedal clutch, the chains were passing close by, too close. With today available chains, not even counting the extra wide o-ring type, are wider than the original chains. While the chains did not hit each other, the extra thickness of the lock clips cause a problem. I was not using any original chain on this Excelsior.
                To solve the problem, I pointed the primary chain master link out, like normal, but the drive chain master link was pointed in towards the wheel. With this master link setup, no more master link lock clip issues.
                It sounds like this may not be your problem, but just an issue to be aware of.
                Like you, I have had been stopped along one section of this one road many times during the many years of riding on the pre-16 motorcycles tour out of the one area. Most times I was able to get back on the road, a few times, not so lucky. Because of that, I would always take it easy in that area.
                Spacke2speed
                • Shaky Jake
                  Ol' Poop
                  • Jan 2013
                  • 261
                  #803
                  Ha! Someday an archeologist with find a small pile of early 20th century Motorcycle part on that spot and conclude that there was a motordrome there. It's some kind of eastern Nebraska Bermuda Triangle.
                  See you next week Charles. Have a safe flight.
                  Kevin
                  Kevin
                  • Shaky Jake
                    Ol' Poop
                    • Jan 2013
                    • 261
                    #804
                    Originally posted by Spacke2speed View Post
                    Kevin
                    Spacke2speed
                    I think I have something like that happening Burgie, but in my case it appears to be the primary cover that's at fault. The chain runs close to it in two places. I'm going to take it off and do some trimming this morning before I load the bike.
                    Kevin
                    Kevin
                    • BigLakeBob
                      • 2767
                      #805
                      Kevin
                      Best of luck Kevin, I'll be following your blog.
                      Bob Rice #6738
                      • Shaky Jake
                        Ol' Poop
                        • Jan 2013
                        • 261
                        #806
                        Thanks Bob. I'm anxious to get started, and tired of packing and loading.
                        Kevin
                        Kevin
                        • Shaky Jake
                          Ol' Poop
                          • Jan 2013
                          • 261
                          #807
                          Kevin
                          Spacke2speed
                          Burgie, I went and looked again, and you were exactly right. The primary chain and the final drive chain pass so close together that occasionally, if one chain drifts left and the other drifts right, the pins on the master link can hit the pins on the primary chain. I did what you said, I put the clip on the final drive chain towards the wheel. I think it will solve the problem. Thanks for the help!
                          Kevin
                          Kevin
                          • Shaky Jake
                            Ol' Poop
                            • Jan 2013
                            • 261
                            #808
                            Brenda and Patience and I finally finished loading on Sunday evening and hit the road for Portland about 8:00 pm on Sunday. We drove all night Sunday night and, except for a few hours at the Henry Ford Museum in Dearborn, we drove all day Monday until about 5:00 pm when we started to feel unfit for duty so we checked in to a hotel in Cleveland, OH and slept for twelve hours. We have another full day of driving ahead of us today. Portland bound.
                            We enjoyed the Henry Ford Museum a lot.
                            Kevin
                            Kevin
                            • Shaky Jake
                              Ol' Poop
                              • Jan 2013
                              • 261
                              #809
                              We got to meet one of Pennsylvania's finest. He said he he pulled me over because he had trouble running my tag, but I think he just wanted to check out my creeper van. Nice young man.
                              Kevin
                              Kevin
                              • hairynob24
                                • Feb 2011
                                • 347
                                #810
                                have a great adventure on your journey keep the photos coming ,Rob
