Post Wauseon
Pin striping resumed today, after the frame was about 20% finished and looking good the striper washed all the striping off. He said he would return tomorrow with a different brush (spear I think).
Instead of fixing the problem with one Okuma (vertical machining center) I took parts from another older turning center (my guinea pig) to get the machining center up and running the quick way. Once back on line I finished leveling the base and squared the head as best as possible for now.
Back to the flywheels, a call placed to Paul Osborn of Truette and Osborn the flywheel guy for a brief conversation. A quick question answered (with basically "I don't know") and casual conversation left me with the knowledge that Paul made flywheels for many of the cannonball bikes, not mine I chose to keep this process in house.
Since the machining center was about ready to run little effort was required prior to cutting the first taper in the center of both flywheels. After a close inspection and over to the surface plate for accurate measurements I determined that the end mill was not ground properly causing the big end of the taper to bell mouth out a few thousandths. More trouble,,, .
With a call placed to my good friend Leo I gathered the flywheels and shafts hopped in the Lincoln and ran over to Leo's. Leo is one of the best toolmakers I know. After he sold his shop and retired he found sitting still was not his forte. So he started a back yard tool makers dream with all the trickest tooling and some great machines.
We set up his Parker Magestic I.D. O.D. grinder by swiveling the head around to I.D. and mounting the 10" magnetic chuck on the work head. Inspected the set up mounted the flywheel on the face of the magnetic chuck indicated it to perfection set the 5 inch sine attachment to 6 degrees (.522 gauge block build up) and lightly dusted the taper in both flywheels to clean up.
Next is to machine the tapers in the crank pin location. I will inspect the taper of the end mill in a whirly jig mounted on a sine plate. If ok I may re-use the end mill, back it out of the hole .2" where the flutes appear to be within tolerance and go for it.
Joe
Joe
