Ryan worked late last night on the bead blaster, he finished up his cylinders and they turned out really good. Anybody that has blasted cylinders in the past knows what a chore this can be.
This morning we inspected them and found a NASTY score in the bore of the rear cylinder. This is a bummer, it will have to be sleeved or replaced. Either way we will work through it and find a good solution.
Ryan told me that he wanted to cut apart his gas tank to beat out the dents and straighten out the shift gate area. So he modified the templet for the oil tank to work on the gas tank, all he had to do was cut a hole in it for clearance for the bladder ofthe gas tank.
Here is the piece after Ryan was done with it.
Ryan cut off the tabs and ground the weld around the whole diameter of the tank.
Here is what he found inside of the tank! Holy Moly there must have been a couple generations of mice living inside of the tank over the last six decades.
