Frame repair
  • Frame repair
    I am wondering if anyone knows of someone who can fix a 741 frame?
    I have a non-matching numbers 741 parts pile that I am working on.
    I recently acquired a very nice original Right side Oil/Gas tank.
    (I am still looking for a Left side tank if anyone has one they are willing
    to sell PM me)
    I went out to my parts pile 741 to do a mock up with my newly acquired tank.
    The bolt holes on the tank would not line up with the bolt holes on the frame.
    I knew the frame had been "repaired" perhaps it would have been more accurate to say
    the frame has been "welded" (Caveat Emptor). Anyway I have been lucky enought to find one outfit that can
    do the job but they are located "Down Under" and I quess I'm a little jealous that my
    parts may be doing more traveling and going to nicer places than I will likely ever get to.
    So before I box this thing up and ship it off I thought I'd ask if anyone knows of someone
    in the USA who could do this? Thanks in Advance.
    Pony tanks on scout frame fit like that....says the Harley guy!
      If you need to take the neck apart and refit tubes and braze everything back ,in a jig,and you are paying someone instead of using your own free labour I think you would be better off and probably cheaper to get anew frame section.They are not that rare.
      Are sure its not the tank thats off?
        "Pony tanks"?
        Duffey; I only have the Right tank, the guy I got it from said it was a 741 and he has been good in the past.
        Additionally it has the "split" front tank mount of the 741:
        Tom;
        No I'm not sure if it's the tank that is off, seems 741 parts are more difficult to find than those for Chiefs.
        You are right I know on flea bay there is a gent out of Europe/Poland selling repo sections and likely it would be cheaper than having this one shipped around the globe and fixed.
        I don't have a frame jig or the experience to take this one on.
        I don't know how good the fleabay sellers parts are.
        And it's . . .just if I go the repo route then what happens to THIS original front section if I don't step up and right it?
        All comes down to abilities and resources. . .I need to think about this; try and find some accurate measurements on 741 frame tank mounting holes and weigh my options.
        Thanks for the input.
          I can get some measurements of my 741 if you need it.Alot of the 741s went to australia so maybe contact someone over there for an original.
          I saw frames on ebay and was surprised at the junk and prices.
            YES PLEASE TOM! I would appreciate the measurements. Here's another tech draw from Jerry Geer:
            I will check out Australia and New Zealand.
              My brothers '42 sport scout little base racer,came with junior scout or pony scout tanks & they fit like that.
              This pic is with the first set of Yellow spear racing tanks that took me about 12 hours to fit properly.
                Beautiful Scout your brother has, Duffey. I'm guessing it's a lot of fun to ride !
                  I never rode it..Sturgis 75th Jim Wall did on the fly adjustments & then did exhibition race with Brittany Olson on Jim's bike.This is built for short track & Jim said it was faster than his bike on that little 1/4 mile track.His bike was built for larger tracks.
                    The rear tank hole to front top is 21 9/16
                    rear to bottom front 17 7/8
                    top to bottom front is 7 7/8
                      Mike at 47Industries in New Jersey did a great job fixing my Harley frame. He does great work, removing tubes and slugging new ones in when needed. Looks completely original too.
                      AMCA #41287
                      2020 Heritage Classic 114
                      1989 Springer Softail project
                      1972 FX Boattail Night Train
                      1972 Sportster project
                      1971 Sprint SS350 project
                        I am sure someone out there has a picture of a reinforced frame at front of section. I am pretty sure I saw a frame once with a reinforcement plate.
                          Tom;
                          Thanks for the measurements I really appreciate the help. I need to get over to China Bobs (Harbor Freight) this week and get a longer steel or aluminum ruler and measure my frame tank mounting holes center to center. as well as the center to center mounting holes on my tank.
                          Mike I will get in contact with 47Industries with my measurements and more pictures Thanks.
                          TomF yes from what I have found a frame gusset support is a good idea, first I need to see If I need the headcasting is properly placed or needs correction.
                          Here is a frame gusset support picture I "borrowed" off Fb:
                            I would research the Jr. Scout tank dimensions, as Duffy said. I also recall the advice of a frame guy who said, "screwing with a neck is the last resort".
                              PaulCDF, Don’t use the guy that welded in that gusset To repair your frame!
