Frame repair
    • 8231
    I hope Duffey's right, Paul,
    And its the tank, not the headstock.
    The caveat is the apparent work at the two intersections; If it was truly a "weld" repair, it could well be ruined anyway.
    Can't weld on 'spelter'. It 'admixtures' into the base metal. Hope and pray they used a torch, and kept it under control!
    PS: Frames were oven-tempered to be springy, and welding a 'gusset' like that can only be a mistake in the long run. Even with pretty beads, which would probably be worse.
    • rustynutz
      • Jun 2016
      • 150
      Originally posted by tfburke3 View Post
      The rear tank hole to front top is 21 9/16
      rear to bottom front 17 7/8
      top to bottom front is 7 7/8
      For future reference “37” SS measurements are: 21 19/32”,17 1/4”, 7 1/4” respectively.
      • bernhardt
        • Dec 2007
        • 67
        The 741 frame dimensions can be found in the Model 45-640 operation and maintenance manual on page 55-2. It discusses how to check the frame for alignment.
        I bought my copy from Greer:
        MANUAL, 1940 ~ May 1943 741 Military 30.50" cubic inch "Scout" and 45" cubic inch "Scout" Factory Repair, excellent source for earlier "Scouts"
        The hard part is finding someone with a frame table and fixture to straighten the thing, but at least this will give you a reference and a place to start. Good luck!
        A. Bernhardt
        AMCA# 9726
        • PaulCDF
          • Aug 2019
          • 1419
          Tom;
          Well the good news is my tank is a 741 and the center to center mounting hole measurements match your frame measurements
          the bad new is my frame measurements do not.
          Bernhardt;
          Brilliant idea I should have thought of the manual. (I got my digital copy from the AMCA Library).
          Here are a few photos of Indian Engineering Au.
          I know, I know it's hard to believe anyone could do a better job at setting this right than me, first time, with my Woolworths yard stick, a hacksaw, some duct tape and JB Weld; but these guys MAY be the ones:
          Anyway I am hoping to get to the EMPIRE Chapter meet in Brookfield this weekend and hope to talk with some friends about this there.
          • PaulCDF
            • Aug 2019
            • 1419
            CORRECTION:
            EMPIRE Chapter meet
            When:
            Friday, August 18, 2023, 8:00 AM until Saturday, August 19, 2023, 5:00 PM
            Where:
            Madison County Fairground
            1968 Fairground Rd
            Brookfield, NY 13314
              • 6010
              "hope to talk with some friends about this there."
              Dang! you New York boys sure do talk funny up there
              You know I'm kidding, Paul. I couldn't resist.
              • PaulCDF
                • Aug 2019
                • 1419
                That's okay grammar and sentence structure never my strong suit.
