Frame repair
  • PaulCDF
    replied
    That's okay grammar and sentence structure never my strong suit.
    replied
    "hope to talk with some friends about this there."
    Dang! you New York boys sure do talk funny up there
    You know I'm kidding, Paul. I couldn't resist.
  • PaulCDF
    replied
    CORRECTION:
    EMPIRE Chapter meet
    When:
    Friday, August 18, 2023, 8:00 AM until Saturday, August 19, 2023, 5:00 PM
    Where:
    Madison County Fairground
    1968 Fairground Rd
    Brookfield, NY 13314
  • PaulCDF
    replied
    Tom;
    Well the good news is my tank is a 741 and the center to center mounting hole measurements match your frame measurements
    the bad new is my frame measurements do not.
    Bernhardt;
    Brilliant idea I should have thought of the manual. (I got my digital copy from the AMCA Library).
    Here are a few photos of Indian Engineering Au.
    I know, I know it's hard to believe anyone could do a better job at setting this right than me, first time, with my Woolworths yard stick, a hacksaw, some duct tape and JB Weld; but these guys MAY be the ones:
    Anyway I am hoping to get to the EMPIRE Chapter meet in Brookfield this weekend and hope to talk with some friends about this there.
  • bernhardt
    replied
    The 741 frame dimensions can be found in the Model 45-640 operation and maintenance manual on page 55-2. It discusses how to check the frame for alignment.
    I bought my copy from Greer:
    The hard part is finding someone with a frame table and fixture to straighten the thing, but at least this will give you a reference and a place to start. Good luck!
  • rustynutz
    replied
    Originally posted by tfburke3 View Post
    The rear tank hole to front top is 21 9/16
    rear to bottom front 17 7/8
    top to bottom front is 7 7/8
    For future reference “37” SS measurements are: 21 19/32”,17 1/4”, 7 1/4” respectively.
    replied
    I hope Duffey's right, Paul,
    And its the tank, not the headstock.
    The caveat is the apparent work at the two intersections; If it was truly a "weld" repair, it could well be ruined anyway.
    Can't weld on 'spelter'. It 'admixtures' into the base metal. Hope and pray they used a torch, and kept it under control!
    PS: Frames were oven-tempered to be springy, and welding a 'gusset' like that can only be a mistake in the long run. Even with pretty beads, which would probably be worse.
  • rustynutz
    replied
    PaulCDF, Don’t use the guy that welded in that gusset To repair your frame!
    replied
    I would research the Jr. Scout tank dimensions, as Duffy said. I also recall the advice of a frame guy who said, "screwing with a neck is the last resort".
  • PaulCDF
    replied
    Tom;
    Thanks for the measurements I really appreciate the help. I need to get over to China Bobs (Harbor Freight) this week and get a longer steel or aluminum ruler and measure my frame tank mounting holes center to center. as well as the center to center mounting holes on my tank.
    Mike I will get in contact with 47Industries with my measurements and more pictures Thanks.
    TomF yes from what I have found a frame gusset support is a good idea, first I need to see If I need the headcasting is properly placed or needs correction.
    Here is a frame gusset support picture I "borrowed" off Fb:
  • tomfiii
    replied
    I am sure someone out there has a picture of a reinforced frame at front of section. I am pretty sure I saw a frame once with a reinforcement plate.
  • joe fxs fxr
    replied
    Mike at 47Industries in New Jersey did a great job fixing my Harley frame. He does great work, removing tubes and slugging new ones in when needed. Looks completely original too.
  • tfburke3
    replied
    Originally posted by PaulCDF View Post
    YES PLEASE TOM! I would appreciate the measurements. Here's another tech draw from Jerry Geer:
    I will check out Australia and New Zealand.
  • duffeycycles
    replied
    I never rode it..Sturgis 75th Jim Wall did on the fly adjustments & then did exhibition race with Brittany Olson on Jim's bike.This is built for short track & Jim said it was faster than his bike on that little 1/4 mile track.His bike was built for larger tracks.
    replied
    Beautiful Scout your brother has, Duffey. I'm guessing it's a lot of fun to ride !
