1940 Chief 340 - Front Fender Light Location
    • 6042
    Thanks for posting the fender light mounting dimensions, Joe. I've looked at vintage, and current pictures, and done mock-ups until I was seeing double. I believe your dimension is correct for a Scout, so I drilled the first hole at 10.44". Due to the different fork configuration, I believe the Scout profile was different than the Chief and Indian made an aesthetic judgement to move the fender light back a bit. Thanks for your input, Joe.
      • 6042
      Tried to post a picture but the forum rejects it.
        • 6042
        This is the error message I get when I try to upload an attachment:
        "Upload failed due to failure writing temporary file."
        Now that's some doubletalk
        • FLFD7
          • Feb 2021
          • 739
          Eric,
          I’m getting the same error messages, it’s not recognizing the picture files for some reason.
          Glad it helped.
          Joe
            • 6042
            Joe, it turns out the picture I was trying to post was too big so I resized it. Again, thank you for the dimension and here's the picture.
            • FLFD7
              • Feb 2021
              • 739
              Eric,
              looking good!
              I resized my photos too, here they are
              • rms337
                • Nov 2015
                • 138
                Originally posted by rms337 View Post
                I will check this weekend.
                Eric,
                I know you and others are way past this, so I apologize for the weekend taking 4 months! I was on a bit of a hiatus. I still wanted to post what I had in the event anyone needed this info in the future. I took some tape to my '41 and '42, cut out the holes and then laid them side by side. Almost exact except for the top hole on the Chief was a bit higher. My measurements were from bottom edge to center of the holes. From the bottom up, my centers were at 9-1/8, 11-1/16 and 14-1/16. See pics below.
                  • 6042
                  Thank you, Rick. I think the difference of fender mounting location for Chief, and Four opposed to the Sport Scout is due to the leaf springs on the big bikes. The S.S. had more open real estate and no protruding leaf spring so I think Indian made the decision to move the fender light back on the S.S. to balance the profile. That was very generous of you to take the time, and make the effort to document those dimensions.
