1940 Chief 340 - Front Fender Light Location
  • 39ChiefBonnie
    • Feb 2014
    • 48
    What is the correct location for the front fender light on a 1940 Chief? How far is the first hole located from the tip? Thank you.
  • kustomizer
    Old Member
    • Sep 2018
    • 58
    My 41 Four is 9 inches if that is of any help
    “People who say it cannot be done, should not interrupt those who are doing it” ― Bernard Shaw
    • Tom Wilcock
      • Jan 2008
      • 333
      I have a 1940 front fender and the first hole is 9 1/8" from the front of the fender to the center of the hole.
        • 4790
        The most important mounting tip I can give for both H-D and Indian is that the lamp top line was parallel to the road surface on all models regardless of fender dimensions.
        • PaulCDF
          • Aug 2019
          • 1431
          As you likely know Kiwi Indian has a Tech video on front fender install. It is for 46 and later but may have some value. Light placement starts ~ minute 9.
          • 39ChiefBonnie
            • Feb 2014
            • 48
            Thank you all for your help.
              • 6034
              Reviving this topic, I'm at the point of mounting a fender light to my '41 Sport Scout. I think the 9.0" - 9.13" dim. is good so I'll go with 9.06" and split the difference. As, Robbie said; Indian, and H-D wanted the top line of that fender light to be parallel to the ground but that is hard to judge with a reproduction fender, and light. I'll mark that dimension on the fender, and see how it looks with the light balanced at that location. Thanks to the members that provided their in-put. That is what makes the AMCA so good.
              • PaulCDF
                • Aug 2019
                • 1431
                At times I find for mock-up purposes something like poster putty works well to temporarily hold things in place so one can step back and 'eyeball' things.
                • ammorest
                  • Sep 2008
                  • 302
                  Paul: What is "poster putty"? Sounds interesting. Thanks.
                  Dave
                  • PaulCDF
                    • Aug 2019
                    • 1431
                    At Walmart:
                    "Product details
                    [Super sticky and reusable] The sticky putty is made of non-toxic materials with strong adhesion. Attach good things and keep them in the correct position. No marks or stains are left on the surface.
                    [Multi-purpose] Sticky sticky sticky sticky putty is very suitable for hanging pictures, posters, notes, decorations, memos, children's art, party decorations. Not suitable for glass or fragile items. A perfect tool to repair your art crafts or nail art. Get rid of the holes in your clean wall. Stimulate your imagination and creativity, just want to use it.
                    [Application] Installation putty is suitable for most surfaces, such as wood, tiles, metal, plaster, plastic, and porcelain. .
                    [Easy to use and remove] How to use --- Take a small piece of putty and rub it on your palm to make it soft and sticky, then put it on the back of the object and press firmly on a clean and dry surface. How to remove it - just roll it off the surface.
                    Material:Clay
                    colour:Pink"
                    • rms337
                      • Nov 2015
                      • 138
                      Eric…I have both my 41 Four and my 42 Chief fenders down to bare metal. I’d be willing to roll out some paper and charcoal and create a template for you if you have any interest. Or I could just measure and see what mine are.
                        • 6034
                        Thanks, Rick, I would appreciate the dimension from front edge of your fenders, to the first fender light mounting hole. I'm going to use a reproduction light, but I do have a genuine Indian fender light that need work on the base, and re-chromed. Just not in the mood to deal with platers right now
                        • FLFD7
                          • Feb 2021
                          • 739
                          Eric
                          I’m having problems uploading pictures (again) but I measured on my fathers 41 Sport Scout and I’m getting 10 3/8 to 10 1/2” from the center of the first mounting hole to the tip of the fender. This bike was done in the 50’s so I gotta think original fender and light. I’ll try later to post the pictures.
                          Joe
                          • ammorest
                            • Sep 2008
                            • 302
                            Paul, thanks for the info on the poster putty. Will check it out. Possibly craft stores like Hobby Lobby or Michael's might carry it also. I have a 1940 Indian 4 in my shop. Fender light first hole is 9 1/8 inches from fender tip to center of hole.
                            Dave
                            • rms337
                              • Nov 2015
                              • 138
                              I will check this weekend.
