65 FLH King of the Highway fit and finish
  • Underdoggie
    • Mar 2009
    • 100
    #121
    Guess Im too late but my measurments match panzforever, here is one from the top to the centerline
    Here is one from the inside edge to the centerline
    Here is one from the back
    John Underwood
    AMCA#14400
    Central Illinois
    • Underdoggie
      • Mar 2009
      • 100
      #122
      Originally posted by rbenash View Post
      Hey UD - stop teasing and post some pics of that B&W 65!
      Ok, here is a couple of shots of my FL up on the stand, I am servicing the front end and wheel bearings for the trip to Davenport in Sept. The last one is of my wife in 1989
      John Underwood
      AMCA#14400
      Central Illinois
      • JSB55
        • May 2009
        • 332
        #123
        Much appreciated, UD.
        That is one fine looking 65. Hope mine looks half as good when finished!
        BTW... the Shovel's pretty sweet looking, too. I have an 81 FXS done much the same way (chrome heads, etc). What's yours?
        Ride it like you can fix it!
        • Underdoggie
          • Mar 2009
          • 100
          #124
          Mine is a 1975, I have had it since 1980,
          Uncle Jack
          John Underwood
          AMCA#14400
          Central Illinois
          • JSB55
            • May 2009
            • 332
            #125
            Hi, Guys
            Back after a bit of a hiatus, and now working on final details on the 65 FLH.
            Very much appreciated the photos above that helped me place the turn signal pilot lamps correctly.
            Now I need a color reference for the outer and inner primary. Mine are in great shape physically, but the inner was painted silver at some point in the past, and the outer is weathered and stained in such a way that I can't tell which shade was the original.
            I know they're sand cast finish and grey, but in B/W photos they appear to have been much darker than the motor cases, whereas in the color photos in the Fields "Panhead" book they appear to have been much lighter, and roughly the same shade as the cases and the cam cover.
            Can anyone help me out?
            I already tried comparing to the MOCO's "Silver Bead Blast" paint, but that shade seems way too light. I'm reluctant to bead blast them, as that may turn them too light a color, and polish off the original gritty texture, which is still intact.
            Thanks in advance for any and all help!
            J.
            • panz4ever
              • Mar 2009
              • 198
              #126
              They are a natural finish....no paint, no nothing.
              • JSB55
                • May 2009
                • 332
                #127
                I know they're natural, but I need a color reference to know what I'm shooting for.
                Been thinking of buying a blasting cabinet, renting a compressor, and blasting them with walnut shells, but I still need to know what shade to go for... i.e, do I try to darken them, lighten them, or what? The outer that I have seems never to have been painted or blasted, yet it has both light and dark areas on it, due to age and weathering, and I don't know which is the original color.
                • rbenash
                  • Jul 2001
                  • 643
                  #128
                  Nice bikes UD!
                  Ray
                  AMCA #7140
                    #129
                    Have them blasted with a soft media, like walnut shell, and walk away.
                    • JSB55
                      • May 2009
                      • 332
                      #130
                      Thanks, Chris. Pretty much what I had decided to do.
                      • JSB55
                        • May 2009
                        • 332
                        #131
                        Harbor Freight carries both 12 Grit Coarse and 24 Grit Fine Walnut shell media.
                        Anybody with experience got a suggestion which is better for cleaning up my weathered outer primary cover and stripping the paint from the inner primary?
                          • Sep 2004
                          • 983
                          #132
                          Thats a real nice 65 pan !!BUT lets not forget the beautiful LADY sittin on it either !!
                            #133
                            [QUOTE=JSB55;79864]
                            Was the original finish on that the same natural sand cast finish as the primary cover, or something else?
                            Natural cast finish is correct.
                            • JSB55
                              • May 2009
                              • 332
                              #134
                              headlamp nacelle
                              Hi, Guys
                              Back after a 6 month hiatus while waiting for parts to come back from the chromer.
                              I'm assembling the turn signal pilot lamps in my headlamp nacelle, and have a dilemma.
                              The lamp assemblies have both a cork washer and a lock washer. Do both go inside the nacelle, or does the cork washer go on the outside (facing the rider)?
                              Thanks again for all the help I've gotten here over the past year.
                              Pics of the finished project will definitely appear here eventually *G*
                              John
                                #135
                                All goes inside.
