65 FLH King of the Highway fit and finish
  • JSB55
    • May 2009
    • 332
    #106
    Sorry for the confusion, guys, and thanks for all the help.
    I'm still getting used to what aged cad plating looks like, and don't always pick up on the (to my eye) subtle differences between the various finishes when looking at black and white photos.
    After massaging the foot peg bracket with a wire brush to remove the silver paint someone had previously applied, I couldn't tell if it had originally been plated, or was "natural" like the trans and motor cases.
    At least the battery box support plate had black paint under the silver, and rust and/or some sort of red primer under that.
    Ride it like you can fix it!
      • 5950
      #107
      The engine and transmission cases are aluminum and can be and were left bare metal, Steel parts are either painted, Parkerized or plated because if you left them bare metal they would rust.
      • JSB55
        • May 2009
        • 332
        #108
        Gotcha. As you've already deduced, metallurgy is not my strong suit.
        • JSB55
          • May 2009
          • 332
          #109
          Getting close to being able to finally assemble and test ride my project.
          It's still a few parts short of a "restoration", so I'll call it a "resurrection" for now, since it's in some ways like the Phoenix.
          Just wanted to thank everyone who contributed information and suggestions. I'm sure I'll have a few more questions before the first ride, but not many.
          Chris, Rooster, paps, "panz", flat-happy, Ray, and everyone else who pitched in... THANKS for the input. The end result will be 100% better than it started out to be, and/or is at the present stage several years earlier than I might have done alone.
          • flat-happy
            • May 2009
            • 543
            #110
            thank you for the mention---i like to help as much as i like to restore. difference is i can always afford to help. can't afford to restore much these days
            • rbenash
              • Jul 2001
              • 643
              #111
              Happy to have helped in any way. The price is that you have to post some pics of the completed project!
              Ray
              AMCA #7140
              • JSB55
                • May 2009
                • 332
                #112
                Back again, guys...
                I'm dealing with an aftermarket headlamp nacelle which does not have the holes for the turn signal "pilot lamps" (rider side indicators), so it will have to be drilled.
                I *do* have the NOS pilot lamps courtesy of Bill's, so I'm good there.
                Could one of you guys who has an OEM headlamp nacelle kindly tell me the size and location of the hole for the pilot lamps? (e.g. X inches from the top and X inches from the inner edge of the nacelle to the center of the hole)
                Thanks in advance. Getting down to the tiny details.
                John
                • JSB55
                  • May 2009
                  • 332
                  #113
                  anybody got the info requested above?
                  • rbenash
                    • Jul 2001
                    • 643
                    #114
                    Mine's not local so can't measure for you or I would. I.E. - at the rebuilder. Apologies.
                    Ray
                    AMCA #7140
                    • JSB55
                      • May 2009
                      • 332
                      #115
                      Thanks, Ray... I'm sure somebody will chime in with the info
                      • Underdoggie
                        • Mar 2009
                        • 100
                        #116
                        I have mine off the bike right now. I made a note and will take measurements tonight.
                        John Underwood
                        AMCA#14400
                        Central Illinois
                        • rbenash
                          • Jul 2001
                          • 643
                          #117
                          Hey UD - stop teasing and post some pics of that B&W 65!
                          Ray
                          AMCA #7140
                          • JSB55
                            • May 2009
                            • 332
                            #118
                            Great, UD... thanks very much in advance!
                            • panz4ever
                              • Mar 2009
                              • 198
                              #119
                              from my 65 2 1/4 by 2 inches. see photo...
                              • JSB55
                                • May 2009
                                • 332
                                #120
                                Cool. Thank you!
