M74 carb
    • 8247
    #46
    Originally posted by joe fxs fxr View Post
    Freeman do you know the jet sizes in your carb? Based upon what you described, the main jet may be too small for your 93" motor. Also float level may be low, contributing to lean at high rpms.
    I don't think, Joe,..
    ...That Freeman's motor is 93 cu. in.
    His Tedd label is for bare cases, and a "P93" wouldn't have been delivered with a Bendix.
    (And he declares it 74" in post #37,,,)
    • PaulCDF
      • Aug 2019
      • 1438
      #47
      “The plot thickens”
      I think we need more information on this engines history, Freeman where and when you get this engine???
      • Freeman
        • Aug 2021
        • 165
        #48
        This gallery has 1 photos.
        • Freeman
          • Aug 2021
          • 165
          #49
          The intake manifold is the same as the shovelhead, it should be 74ci, The intake manifold is the same as the shovelhead, it should be 74ci, but it is not decided, the cylinder volume is not large, the carburetor caliber is 40, and the injection pipe can not be replaced.
          • joe fxs fxr
            • Dec 2020
            • 706
            #50
            Can you make the picture larger? Or type out the description?
            AMCA #41287
            1971 Sprint SS350 project
            1972 FX Boattail Night Train
            1972 Sportster project
            1973 HD Golf Cart project
            1989 Springer Softail project
            2020 Heritage Classic 114
            • Freeman
              • Aug 2021
              • 165
              #51
              • Freeman
                • Aug 2021
                • 165
                #52
                • Freeman
                  • Aug 2021
                  • 165
                  #53
                  • Freeman
                    • Aug 2021
                    • 165
                    #54
                    • Freeman
                      • Aug 2021
                      • 165
                      #55
                      • joe fxs fxr
                        • Dec 2020
                        • 706
                        #56
                        Cotton you are right, V-Twin Part number 55-5008 is the complete bike:
                        Our 1948 Replica Panhead Kit is an authentic style reproduction of the original. 74" V-Twin replica motor assembled and factory tested.
                        No word on what carb came with it, but I expect they put the right jets in the carb.
                        AMCA #41287
                        • Freeman
                          • Aug 2021
                          • 165
                          #57
                          100%copy……Ignition system, carburetor, transmission, none of them.
                          • Freeman
                            • Aug 2021
                            • 165
                            #58
                            • Freeman
                              • Aug 2021
                              • 165
                              #59
                              • pan620
                                • Oct 2016
                                • 223
                                #60
                                Why would you expect that?
