M74 carb
  • PaulCDF
    • Aug 2019
    • 1438
    You may buy where ever you wish.
    I am just suggesting placing a Want Ad in the forum and the Club magazine as both are read by old bike enthusiasts like ourselves.
    Someone may have a M74 carburetor for sale.
    • Freeman
      • Aug 2021
      • 165
      That's a great idea. Thank you.
      • Dablaze
        • Apr 2011
        • 157
        Are the Colony or reproduction intakes decent? They look pretty convincing in pics.
        Craig
        • Freeman
          • Aug 2021
          • 165
          Craig
          I don't understand.
          • Dablaze
            • Apr 2011
            • 157
            As Tom said, the intake manifolds for the Linkert can be a real pain. Often they have been polished out of shape, damaged and/or hard to find a decent one. Probably other issues I don’t even know about. There are different widths for a 61” or a 74” if you are running the early plumber style intake manifold. I have one but it was dechromed and the polishing before chroming made it so it won’t seal.
            craig
              • 8247
              We need to know the vintage of your cylinderheads, Freeman...
              There were two basic designs: The 1948-1954 compression ferrule design (often called "plumber's-style"), and the 1955-1965 O-ring design. Clear photos of your motor would answer many questions.
              And I de-chrome and refit worn plumbers' manifolds routinely, Craig!
              (Although it costs extra blasting time.) Worn spigots are swaged to shape and re-cut true and round, before seals are custom-cut to a perfect fit.
              I have come to find the "different widths" dogma highly suspicious.
                • 2025
                Cotten I disagree with the 'different widths' dogma. I do not think HD had different widths between 61 and 74. Parts books do not show a difference either.
                Jerry
                  • 8247
                  Originally posted by Jerry Wieland View Post
                  Cotten I agree with the 'different widths' dogma. I do not think HD had different widths between 61 and 74. Parts books do not show a difference either.
                  Jerry
                  I hope, Jerry, ..
                  You meant we both disagree with the dogma. Manifold myths don't stop there, but that deserves a separate thread!
                  I look forward to Freeman's photos, so we all can help him sort out his needs.
                  • kitabel
                    • Sep 2018
                    • 471
                    The difference between EL and FL would rest entirely with a function of the difference in cylinder height, which is .125" (5.33" - 5.205"). A triangle can be found with the angle at 22.5°, the hypotenuse is .125", and the side opposite is the added width (per side).
                    Looks like the extra width is only .048" per side (.096" total), is this within the range of seal placement?
                    The Linkert Book
                      • 8247
                      Good question for a manifold myth thread, Kitabel!
                      But let us see from Freeman's photos what he needs, as it may be O-ring design.
                      • Freeman
                        • Aug 2021
                        • 165
                        My panhead is not original, it is newly assembled, the crankcase is S & S and the cylinder is 74ci. The first thing to do tomorrow morning is to take pictures. Thank you for your communication.
                        • Freeman
                          • Aug 2021
                          • 165
                          #27
                          This gallery has 1 photos.
                          • Freeman
                            • Aug 2021
                            • 165
                            #28
                            Found a photo from that time.
                              • 8247
                              #29
                              It appears, Freeman,...
                              You have modern aftermarket heads that accept a Shovelhead manifold.
                              Even if you fabricated a custom manifold to accept a bronze Linkert, it would interfere with your knee.
                              You could install a 1966 Linkert DC7 Model and manifold, but it would be hard to justify the effort and expense.
                              .....Cotten
                              • kitabel
                                • Sep 2018
                                • 471
                                #30
                                The math above only covers "T" shaped intake manifolds.
                                I wrote an Excel spreadsheet that automatically calculates the width change (in std. and metric), For use on Indian engines, change the angle to 21°.
                                PM me for a free copy.
                                For the "V" manifolds (shovel, 45, UL, Sportster, Indian, K) a second calculation is needed for the manifold angle, still working on it
                                The Linkert Book
