M74 carb
  • Freeman
    • Aug 2021
    • 165
    #31
    It appears, Freeman,...
    You have modern aftermarket heads that accept a Shovelhead manifold.
    Even if you fabricated a custom manifold to accept a bronze Linkert, it would interfere with your knee.
    You could install a 1966 Linkert DC7 Model and manifold, but it would be hard to justify the effort and expense.
    .....Cotten
    I'm thinking about it.. Thank you for your advice.
    • Freeman
      • Aug 2021
      • 165
      #32
      This gallery has 2 photos.
      • Freeman
        • Aug 2021
        • 165
        #33
        This gallery has 1 photos.
        • Freeman
          • Aug 2021
          • 165
          #34
          • Freeman
            • Aug 2021
            • 165
            #35
            • Freeman
              • Aug 2021
              • 165
              #36
              • Freeman
                • Aug 2021
                • 165
                #37
                This carburetor doesn't feel like it matches my 74ci panhead
                  • 8247
                  #38
                  Your heads appear to not be OEM Panheads, Freeman,..
                  The intake ports and valves may be much more like a Shovelhead.
                  But that does not mean your Zenith Bendix carburetor is a poor choice, if all is in order. It should perform stronger than a Panhead.
                  Does the motor balk and run poorly?
                  • Freeman
                    • Aug 2021
                    • 165
                    #39
                    • Freeman
                      • Aug 2021
                      • 165
                      #40
                      I can't figure out the details of the engine. This is the label of the engine at that time. This carburetor starts easily, but at high speeds it doesn't feel like it has enough fuel
                      • kitabel
                        • Sep 2018
                        • 471
                        #41
                        There is no "crankcase set fits1948-64".
                        The Linkert Book
                          • 8247
                          #42
                          Your V-TWINⒸ label only describes the replica motor cases, Freeman...
                          It tells us nothing of the internal components, nor the heads themselves. A hand covers the exhaust port in your photo of the motor, but I suspect it is Shovelhead design as well.
                          (They are not accurate "replicas", but modernized hybrids between Panheads and Shovelhead designs.)
                          Still, it should run strong if all things are in order.
                          So let us first apply a diagnostic test to be certain there are no vacuum leaks that might mimic a fuel-starved condition: http://virtualindian.org/11techleaktest.html.
                          Testing while installing your manifold will prevent over-tightening of the clamps; Please avoid any clamps with larger than a #10 screw fastener.
                          If zero bubbles are produced at a constant, regulated 15psi (1 atmosphere) of pressure, we can move on to other possibilities.
                          • PaulCDF
                            • Aug 2019
                            • 1438
                            #43
                            Freeman
                            Appears you have S&S engine model P3
                            Per: S&S site:
                            "The S&S P93 features:
                            • Designed for stock or custom 1948-1964 Harley-Davidson® generator style chassis
                            • Super E carburetor
                            • Heads are a new design based on S&S heads for shovels"
                            Looks like a nice engine. Good Luck.
                              • 8247
                              #44
                              I'm really not familiar with modern carbs, Paul,...
                              But I know that is not a Super E in Freeman's photos.
                              It is a Bendix that might need a new accelerator pump and boot, but beyond that I know little of them (except for a few rebuild kits in my dead inventory).
                              • joe fxs fxr
                                • Dec 2020
                                • 706
                                #45
                                Freeman do you know the jet sizes in your carb? Based upon what you described, the main jet may be too small for your 93" motor. Also float level may be low, contributing to lean at high rpms.
                                AMCA #41287
                                1971 Sprint SS350 project
                                1972 FX Boattail Night Train
                                1972 Sportster project
                                1973 HD Golf Cart project
                                1989 Springer Softail project
                                2020 Heritage Classic 114
