48 Panhead Timer Question
  • harleygreg
    • Oct 2018
    • 215
    Hi, I am intending to replace the incorrect timer with this one
    Equip your Harley with our circuit breaker assembly for OHV Big Twins (1936-1960). Replaces HD 32505-36, 32575-37.
    From reading Palmers manual, it is unclear whether this was operated manually at the timer, or through a cable to the left handlebar grip. Can anyone advise?
    Thanks, Greg
  • jwl
    • Dec 2001
    • 338
    Control cable from handlebar.
    • Rubone
      • Aug 2004
      • 4767
      All are controlled from the twist grip up until the Auto advance on the '64 Servi-Car and '65 Panhead. However, the timer you picture is not correct for '48. The '48 timer is the newer configuration with the sliding post protruding out the side. For '47-'48 they still used the early points, in '49 the points changed but outward appearance stayed the same.
      • Hack
        Senior Memeber
        • Sep 2010
        • 91
        Here you go Greg.
        • harleygreg
          • Oct 2018
          • 215
          Thanks Guys, terrific response to the first of many questions - it also appears that the advance cable is held in place by a clip attached to the relay support? I'll deal with the parkerised v's chrome at a later date.
          Control Coil Bracket by Colony for 45” models (1937-1948). Steel construction, replaces HD 4162-30 & 9967.
          Paughco Delco relay bracket for Knucklehead & Panhead (1947-1964). Steel, bare finish. Replaces HD 74765-47.
          Greg
            • 5978
            I didn't know that the '48 still used early points. Is there any difference between early, and later points in regards to function, or performance?
            • Jerry Wieland
              • Jan 2006
              • 2012
              Nope just the expense of trying to buy the early OEM points. Jerry
                • 5978
                Sometimes those things can make a difference. Thanks for your insight, Jerry.
                • Rubone
                  • Aug 2004
                  • 4767
                  Lots of early timer heads are around with damaged points posts, posts broken off, insulating washers missing, etc. I usually do a simple mod and use '70 up Shovelhead points in them.
                  • Chris Haynes
                    Curmudgeon
                    • Jul 2002
                    • 5940
                    The timer type you picture ended production in 1946.
                    • Jerry Wieland
                      • Jan 2006
                      • 2012
                      Sure looks like a 47/48 timer to me. Educate me Chris.
                      • duffeycycles
                        • Apr 2010
                        • 2019
                        Jerry,'47 was the first year of timer without the strap,changed to later points in '49
                        • len dowe
                          • Oct 2002
                          • 503
                          I believe it has to do with the wire stud. Meaning the circuit breaker wire stud, not the adjusting screw.
                          AMCA #765
                            Gadfly from the Dumpster
                            • 8222
                            While we are dissecting timers, Folks,...
                            Can anyone identify the base on the left?
                            Note the advance slot is in a very awkward place.
                            Thanks in advance as always,..
                            • Robert Luland
                              • Sep 2007
                              • 2075
                              You plan to restore this back to AMCA judges standards by putting that after market junk on it? Those are your words. Bob L
                              AMCA #3149
