G,day Bob.
No inaccuracy intended.
Without facial expressions and tone of voice, there is a phenomenon where text sometimes looses its intended mark.
The word "Nice" is to show my appreciation for your gauges and functionality of the dual readout.
The description " barrel reads 001" and the gauge reads 0001" refers what I like about your gauges.
Appreciate your contributions to the thread.
Regards Steve
Fixture
Reading your reply makes them sound inaccurate I must admit, but they are meant to be set at any given size by using gage blocks which are in .0001 increments. If I am grinding a diameter I use my standard mic until I get under a .001 then use these to finish, my OD grinder moves in .000025 increments. When checking 1/4" bearings I would set the mic using .2500 gage blocks then read the dial +/- in the .0001 increments. Not trying to sway from your thread, just thought I would share another type of measuring device.Originally posted by Steve Little View PostNice. The barrel reads 001" and the gauge reads 0001".
Hi Peter. I had a quick look and could only see 6 messages in there.
It took another 15 minutes to work out that I needed to click another box to see that I had replied to 44 messages.
I'm not the sharpest tool in the shed.
Here's my measuring gizmo.
Beautiful English quality Mercer gauge and Mitutoyo base.
Accurate, repeatable quality.
Someone once told me that "you will know when you have all the tools you need" I am still waiting for that realization.
Always. Sometimes the whole package is close to the next oversize or often undersize.
Hi Bob. Thanks for contributing ideas. I will have to buy a 0001" indicator to fit to my mag bases. I have 3 that measure 001" but the only 0001" gauge is for checking new loose rollers before fitting them to engines, transmissions, star hubs etc.
The number of incorrect rollers in a pack of 100 is alarming.
I buy rollers in packs of 100 and used to trust what was written on the envelope, but now I check every roller. I regularly find rollers 0001" to 0002" out of spec.
Anybody else check the rollers?
Steve, Looks like you are getting some really nice results, great job. Attaching a dial indicator with a .0001 readout to a mag base may help not seeing the dial plus also help with accurate in feed, but then again you are getting along just fine.
It worked a treat!!! Dead on 0.750”
The top shaft is the reamed shaft and the bottom shaft is grind only. The finish of the grinding is very nice but the reamer leaves a very nice feel.
The lip on the end of these ground shafts is razor sharp. If I left it like this, the sharp lip would ruin a seal when the shaft was pushed through it. I checked the OEM shafts, and Harley have a nice safety edge so that it wont cut the quad seal.
Tried a file first but the hard chrome just laughed at it.
Different story with the emery. We now have a nice safety edge.
¾ hour cleaning and oiling up the lathe.
All Finished.
Now that I have accumulated all this grinding knowledge (1 shaft), I did the second shaft in half the time.
I was only taking 005” cuts (010” overall diam) the shafts don't seem to get very warm. I can easily lay my hand on it.
But once bitten, twice shy... So I let the shaft cool down to air temp before measuring for the last pass.
Made the adjustment, set the feed to Slowest and flicked the feed on. I was shooting for 000' but ended up 0005” oversize....Damn it!!!
This Waldown C-2 grinder is excellent Australian quality, and I am guessing that the model designation “type 2-C” means there may be smaller and larger models available.
The advantage of a smaller model would be, no overhang obscuring the cross slide readout.
During the final cut I stopped 1/4” inch to check the measurement. It was perfect but I had another idea.... Try finishing off with the Sunnen hand reamer.
Thanks guys.
The tea towel came in covering a meal some time back. The “Return To Kitchen” policy may have slipped my mind.
There was some muttering and grumbling as she left the workshop yesterday.
I hazarded a glimps up from the job, she was busy picking up 5 cups on the way out.
