Out-of-my-league manifold question
    • 6044
    I have heard that too Peter, and I wonder if that is typical of 1915 cylinders. I always look at the fins around the exhaust cover but there must have been a number of pattern changes on those cylinders over that '15-'16 period.
    • MMasa
      • 1192
      I have a "1915" cylinder with wrap around fins and a round top screw boss. Late 1915/early 1916? Who can say now what was happening in the foundry back then.
      Btw: the gearcase cover / oil pump on that 16 engine pictured is a Fred Lange reproduction.
      Mark
      Mark Masa
      www.linkcycles.com
        • 2044
        I'm no expert but have had both styles of these cylinders.On my early motor the boss is rounded,and on my very late '15 motor they were squared.This pic is my early '15 serial number 3,xxx
          • 2044
          Notice the motor in this thread has a lower fin around the setscrew than my motor and the setscrew boss is closer to the top of the cylinder.Many of these '15-early'16 motors have later[late '16-'19] cylinders that have the wrap around part added to make them look like '15-early '16.I think that is what this motor has.I know builders who have done many later cylinders this way.Also notice the thickness of the top fins[all fins] is thicker on the motor in question.
            • 2044
            Back To Cotton's question.Check out his 1923 MECO catalog offer at bottom left.
              • 2044
              '15 single carb#2985 is screw on...'15 twin carb#2995 is bolt on
                • 8248
                That's appalling, Duffey!
                But it explains a lot of boogered manifolds, thanks.
                  • 2044
                  I knew you would like that
                    • 8248
                    Unfortunately Duffey,
                    Four or five tries and I still cannot convert it into a format that my photoeditor will accept.
                    (Photobucket sucketh.
                    All external photohosting sucketh.)
                    If I could cut'n'paste from it, many Folks would enjoy.
                    And I don't mean just the cute pistol. (Clues to the real maker with this folding trigger, anyone?)
                    The 'Lock-Jaw Nipple Grip" is just as cute as its name, because it looks serious.
                    Back to topic example:
                    That looks like a red Bakelite knob. It all looks too serious.
                    PS: Wish I still needed that kind of supporter.
                      • 2044
                      I agree with the Fred Lange parts,but isnt the cases also repro?
                      This is original case.Letters look different.
                        • 6044
                        Thought a up/down comparison would make it easier.
                        URL=http://s534.photobucket.com/user/cdo340/media/fiff_zpsfwz4oyzq.jpg.html][/URL]
                          • 2044
                          #27
                          Thanx Eric,That was something I haven't figured out!Notice the cutout for the upper right case bolt does not look the same.
                            • 6044
                            #28
                            I see what you mean. I thought the M in Milwaukee looked a bit off to the H and A in Harley. I guess it's all academic; like when someone says, "you don't look so good", and you start feeling sick
