Originally posted by Robert Luland
View Post
Originally posted by Robert Luland View PostThat seal puts you beyond the bearing area. It is pressed into the end of the main drive gear and is there just to seal where the shaft passes though it.I don't mean to brag but; I put together a puzzle in only a week when the box clearly said "2-4 years".
I found a hub race that hasn't been trashed by earlier mechanics IMG_2175.jpg I was hoping the 2495-30 rivets were 1/4" diameter but alas no...17/64". In case anyone finds themselves in the same position and has the idea that they might be able to swell a 1/4" steel rivet and make it work, I recommend just finding (or making) the 2495-30 rivets and doing the job right.I don't mean to brag but; I put together a puzzle in only a week when the box clearly said "2-4 years".
Originally posted by Robert Luland View PostWhere do you come up with this stuff. The rivet is .250. I rivet these things all week long for folks.
My reasoning was based on the following (1) I had three hubs where all the holes measured between 17/64 up to .274 IMG_2178.jpg and (2) Harley gave a 2495-30 part number to the rivet which I figured meant something other than a simple flush head rivet. Why in the hell would they give a common rivet a special part number???? The only people lazier than mechanics are engineers and they don't usually develop a part number (which requires some kind of documentation) unless there's a significant change in fit, form or function.
But yes, it turns out that it's just a common 1/4" flush rivet as far as I can tell unless my supplier has mislead me.I don't mean to brag but; I put together a puzzle in only a week when the box clearly said "2-4 years".
Hub successfully installed:IMG_2179.jpgIMG_2181.jpgIMG_2180.jpg Those rivets are a bitch kitty to install, I see why the hole oversized now.I don't mean to brag but; I put together a puzzle in only a week when the box clearly said "2-4 years".
Okay so the finish on my bottom studs was worn off so I made this my first experiment at Parkerizing IMG_2186.jpg I cooked them at the recommended temp 190-210 F for 45 minutes IMG_2187.jpgIMG_2188.jpg and installed IMG_2189.jpg. I would have hoped they would have been darker after 45 minutes. The ratio I used was about 1:8 ounces.I don't mean to brag but; I put together a puzzle in only a week when the box clearly said "2-4 years".
Originally posted by Grumpa View PostHub successfully installed:[ATTACH=CONFIG]22848[/ATTACH][ATTACH=CONFIG]22849[/ATTACH][ATTACH=CONFIG]22850[/ATTACH] Those rivets are a bitch kitty to install, I see why the hole oversized now.Last edited by Robert Luland; 10-07-2018, 06:59 AM.
Originally posted by Robert Luland View Post45 minutes? When the fizzing stops, the operation is over. Usually 5 to 8 minutes.I don't mean to brag but; I put together a puzzle in only a week when the box clearly said "2-4 years".
Yea! Parts back from cadmium plating IMG_2207.jpg Hat's off to Retrocycle.I don't mean to brag but; I put together a puzzle in only a week when the box clearly said "2-4 years".
So prior to the re-build I made a weld fixture: IMG_2210.jpgIMG_2211.jpgIMG_2211.jpgIMG_2212.jpgIMG_2213.jpgIMG_2214.jpgI don't mean to brag but; I put together a puzzle in only a week when the box clearly said "2-4 years".
So I've shot myself in the foot here. Installed the studs IAW the suggested stud heights with red Loctite. The top long studs @ 11/16" were too short IMG_2224.jpg and destroyed one of them adjusting to 7/8"IMG_2229.jpg. The side studs installed @ 1/2" IMG_2225.jpg adjusted to .6" IMG_2230.jpg. I should have checked before installing with Loctite for crying out loud.I don't mean to brag but; I put together a puzzle in only a week when the box clearly said "2-4 years".
