VL Trans rebuild
  • Grumpa
    • Nov 2014
    • 137
    Originally posted by Peter Cooke View Post
    I've been assuming the Chain Guard Clutch Plate would be gloss black to match the Front Chain Guard inner upper & lower pieces.
    That's pretty much what I figured as well Pete thanks man.
    Originally posted by Steve Slocombe View Post
    They're usually covered in rust and filth when I see them....These are not items which give me sleepless nights.
    Lol me either, it's just that since everything's apart and cleaned up I thought I'd ask. Thanks Steve
    I don't mean to brag but; I put together a puzzle in only a week when the box clearly said "2-4 years".
    • Grumpa
      • Nov 2014
      • 137
      Okay so I need some education here. My 2296-31 main drive gear has oil passages: IMG_2077.jpg which would indicate movement relative to the mainshaft bushing 2297-31. Yet the 2297-31 bushing has oil passages on the ID as well which would indicate movement relative to the mainshaft. What am I missing? Is the 35094-31 bushing the same as the 35094-65 split back bushing?
      • Peter Cooke
        • Aug 2012
        • 570
        I think that's actually a 2296-25 main drive gear. Looking at your 5th photo in post#7 and reading Steve's comments in post #10 re the bore sizes you may have your part numbers around the wrong way in your photo.
        It reads like the earlier gear has the smaller ID and needs to be bored to use the later bushing.
        In the earlier set up the bushing was soldered to the mainshaft which would explain the oil passages in the main drive gear.
          Yes, it is the -25 main drive gear which has the spirals cut in the steel, and less wide teeth than the -31 version. The -65 bushing is shorter than the original -31 VL one, but all we can find these days and seems to do the job.
          • Grumpa
            • Nov 2014
            • 137
            Okay now I understand a little better now, thanks! What came out of the tranny was the 2272-30 shaft with the 2296-31 gear, NOT the 2296-25 spiraled gear like you'd expect (thus my confusion). That helps a lot, thank you gentlemen.IMG_2080.jpg
            • Grumpa
              • Nov 2014
              • 137
              Okay so I installed the shorter 35094-65 bushing midway in the main gear IMG_2083.jpg IMG_2084.jpg as opposed to favoring one side or the other. If someone has another theory, please educate me.
              • Grumpa
                • Nov 2014
                • 137
                Doing a dry run re-assembly, tranny is good. Bearings were nominal and ended up replacing with oversize on the countershaft. IMG_2105.jpg The L/H were a plug fit at .0008 and I installed .0004. The R/H were a plug fit at .0006 and I installed the 92222 .0004 o/s there as well. The old countershaft thrust washer was .078 and replaced with a .083, a new 2309-32 c/s gear end plate and I still have a .005 end play when it should be .001. Have a 2309-16 c/s bearing collar on the way which will hopefully fix the end play issue. I modified the mainshaft installation with sealed bearings IMG_2115.jpgIMG_2119.jpg so I left the brass oil seals out.
                • Grumpa
                  • Nov 2014
                  • 137
                  So on fitting the clutch; the old mainshaft measured 1.0000 at the clutch 2494-30 race area the new mainshaft is 1.0005. The race measured 1.5005. The bearings were .250. Noted that the 2500-19 roller bearing washer had metal smear IMG_2143.jpg and the race was mushroomed. I replaced the mainshaft and it measures 1.0005 and of course it's a plug fit now with the nominal .250 bearings and 1.5005 race. My plan is to hone out the race another .0005.
                    Countershaft gear end float is usually reckoned as free running to 0.010" so you're OK.
                    • Grumpa
                      • Nov 2014
                      • 137
                      Awesome! I was going by your book IMG_2144_LI.jpg so that's a typo. If you ever want some editing I'll volunteer free of charge if you think you'll come out with another edition.
                      On another note, I have a wide selection of clutch bearing thrust washers 2500-19; from .0889 to .1195. What's the goal here? As noted above, something was wrong with the last guy's assembly because the hub was mushroomed and the washer had metal smear. The bearing cage length exceeds the hub.
                        Thanks for the typo spotting. On 2500-19, the idea is to find a washer not so thin as to allow the clutch drum to wobble, nor yet so thick as to bind/drag against the clutch drum. The roller bearing assembly should be slightly shorter than the clutch hub, so something needs looking at again.
                        • Grumpa
                          • Nov 2014
                          • 137
                          #27
                          Sorry Steve, I really wasn't highlighting your typo so much as providing a reason for why...never mind. So I scournged up another race IMG_2145.jpg and my guess is that the last guy had too thick a thrust washer. So now that I have re-read your clutch removal instructions I see that there needs to be .005"-.010" end float. I'd move that bit of info to the reassembly section as your hopefully helpful critic/editor; even though I read it on disassembly I'm afraid I've slept since then.
                          • Grumpa
                            • Nov 2014
                            • 137
                            #28
                            I used to write/edit technical aviation manuals for the military in addition to turning a wrench, so I do apologize for being anal, lmao (pun intended).
                              #29
                              The bushing was shortened to allow the main shaft seal on 1965 and later main drive gears. You could have ground that area and gotten the best of both worlds.
                              • Grumpa
                                • Nov 2014
                                • 137
                                #30
                                Yes sir, I forgot about that and I'll put in a seal when I take it back apart. I was just doing a dry run fit check while I was waiting for Rob Nussbaum to get done clowning around with the cannonball and get back to cad plating....
