Originally posted by tfburke3
View Post
101 Scout... going to take a while
That's where I was headed Tom, finally fitting the engine/gearbox into the frame with the wheel to see how everything lines up. The kicker stud that was in there originally was offset and brazed in place, so I know I'll have to deal with that, too! BTW, there isn't a lock tab washer on the sprocket side on this one, only on the clutch sprocket nutPisten Bully is Harry Roberts in Vermont.
I managed to get the drive gear out tonight. It’s 1.196” from the bearing face to the face of the nut when it’s tighten down ‘hand tight’.
Good luck
I'm continuing to mock things up to make sure everything goes together, and each new piece added creates a new challenge! I finally finessed, wrangled, and persuaded the front fender to fit and immediately found another issue. I was aware that the frame down tubes in front were bent, I had measured the wheelbase earlier and came up about 3/4" short, but the tank fit and the fender fit...or so I thought.
Discovered that the fender, with the original full length stays in place barely cleared the frame:
And I was already aware of where the problem lay, the down tubes into the fork neck were bent backwards a bit:
So I straightened them:
... and now the tank and the fender both fit correctly!Last edited by pisten-bully; 11-06-2019, 01:55 PM.Pisten Bully is Harry Roberts in Vermont.
Nothing like the miracle of hydraulics, Harry
. Brilliant solution to a nasty problem. I love your build thread, and the work you have done, and the documentation, and pictures you have taken the time, and trouble to post for us.
Looks just like something I’d have done. Good job. Great thread!
Originally posted by pisten-bully View PostI'm continuing to mock things up to make sure everything goes together, and each new piece added creates a new challenge! I finally finessed, wrangled, and persuaded the front fender to fit and immediately found another issue. I was aware that the frame down tubes in front were bent, I had measured the wheelbase earlier and came up about 3/4" short, but the tank fit and the fender fit...or so I thought.
Ahhh... the Porta-Power! Funny thing, I purchased that when my now 40 year old son was 18 and bent the cross member in a 4-wheel drive we had when he hung it up on a stump...he also rolled three different cars! Now he's an airline pilot.... I told him I hope your rolling days are over!Originally posted by exeric View PostNothing like the miracle of hydraulics, Harry
Which airline? Just wondering... ;-)Originally posted by pisten-bully View PostAhhh... the Porta-Power! Funny thing, I purchased that when my now 40 year old son was 18 and bent the cross member in a 4-wheel drive we had when he hung it up on a stump...he also rolled three different cars! Now he's an airline pilot.... I told him I hope your rolling days are over!
Kevin
Ah, well then! Thank him for his service!Originally posted by pisten-bully View PostWe all dodged the bullet, he switched from flying people on SW to motorcycle parts on UPS...whew!
Kevin
I am wondering about the following: when I made a first attempt to fit the front wheel with the rockers installed I found the spread of the forks is too narrow. The hollow axle requires about 5" of width between the mounting holes and I only have about 4 1/2". So I rigged up a simple way to spread the forks, or actually the axle holes in the rockers, to 5". It didn't really take much force to get there, but when I release I lose almost all that I gained. So my question is, do I continue to spread farther and farther and release, going in 1/2" steps until I get the desired 5" to stay in place, or should I be thinking about some other method? Thanks!
I am far from being anything but a metal bending hack. Wonder if you need some slight reversed pressure/restraint up further on the forks to delicately allow ever so slight bending and counter act the memory as you expand out from the bottom. Possible another all thread with plates on each end tightened instead of expanded. I wouldn't know where to restrain it in the upper area for the fork - maybe at the point where the rim is? It probably would not take much to change the memory of the steel.Originally posted by pisten-bully View PostI am wondering about the following: when I made a first attempt to fit the front wheel with the rockers installed I found the spread of the forks is too narrow. The hollow axle requires about 5" of width between the mounting holes and I only have about 4 1/2". So I rigged up a simple way to spread the forks, or actually the axle holes in the rockers, to 5". It didn't really take much force to get there, but when I release I lose almost all that I gained. So my question is, do I continue to spread farther and farther and release, going in 1/2" steps until I get the desired 5" to stay in place, or should I be thinking about some other method? Thanks!
When you spread the forks out, were the rockers still aligned enough that the axle would pass through them?
Kevin
That works on girders, Harry!Originally posted by pisten-bully View Postdo I continue to spread farther and farther and release, going in 1/2" steps until I get the desired 5" to stay in place, or should I be thinking about some other method?
PS: I always wanted a 'portapower';
Fortunately, this Hen owner brought his own.Last edited by T. Cotten; 11-10-2019, 10:49 AM.AMCA #776
