Powerplus or Bust, Eh?
  • Tom Lovejoy
    • Aug 2006
    • 951
    #706
    Very cool Kevin, what gains do you expect from using the Nylatron material ? just curious
    • BoschZEV
      • Jul 2012
      • 521
      #707
      I also wondered why you didn't use bronze. Great thread, by the way (great threading, too...).
      • Shaky Jake
        Ol' Poop
        • Jan 2013
        • 261
        #708
        Hi Tom. I'm just lazy I guess. If I'd have stuck with the original hardened steel, I would have had to make them, them harden them, then hone them. With the Nylatron I just had to make them.
        Don't judge me too harshly. ;-)
        Kevin
        Kevin
        • Shaky Jake
          Ol' Poop
          • Jan 2013
          • 261
          #709
          Bronze was certainly an option. I don't have any strong reason for choosing Nylatron over bronze. I guess once you decide to deviate from original it opens the door to many options. I ended up going with Nylatron on the advice of a respected friend who has had good experience with it in the past. Time will tell how well it works in this application. I pretty sure it will at least get me to the finish line.
          Kevin
          Kevin
          • BoschZEV
            • Jul 2012
            • 521
            #710
            It struck me as a pretty big jump to go from hardened steel, to plastic, but going on a recommendation you trust makes sense.
            • Shaky Jake
              Ol' Poop
              • Jan 2013
              • 261
              #711
              Call me a risk taker. ;-)
              Kevin
              Kevin
              • Shaky Jake
                Ol' Poop
                • Jan 2013
                • 261
                #712
                One more thing on the swingarm. This is the bolt that threads into the frame and clamps the swingarm pivot in place. It's supposed to have a little nub on the end to engage that hole in the pivot shaft.
                I could have made a new one, but I decided to renub the old one instead.
                Kevin
                Kevin
                • Shaky Jake
                  Ol' Poop
                  • Jan 2013
                  • 261
                  #713
                  Kevin
                  Kevin
                  • TechNoir
                    • Dec 2015
                    • 301
                    #714
                    Hi Jake, they look very clean and shiny, are they for your original engine or for the second engine that you mentioned a little while ago?
                    John
                    • Shaky Jake
                      Ol' Poop
                      • Jan 2013
                      • 261
                      #715
                      John
                      It is my original Cannonball engine. There was almost no paint left on them, so I decided to blast and paint. Hopefully it won't stick out too much on my old paint bike. I didn't blast the timing cover, because it still has some original paint.
                      Kevin
                      Kevin
                      • Shaky Jake
                        Ol' Poop
                        • Jan 2013
                        • 261
                        #716
                        I'm changing my piston design for the 2018 Cannonball. I've gone with a more full skirted design, which is more like the originals. They are quite a bit heavier, which will improve my balance factor without drilling a bunch of holes in my flywheels. It seems like a step backwards, but I think the additional surface area and mass will make them more robust in this air-cooled, sling-oiled, low RPM application. Time will tell. Also, I'm using buttons instead of clips. I didn't have any problems with the clips, but buttons tend to be more reliable and easier to install. The 2016 piston is on the left, 2018 on the right:
                        Kevin
                        Kevin
                        • BoschZEV
                          • Jul 2012
                          • 521
                          #717
                          I'm glad to see that you're making good progress. I was getting a little worried by the lack of posts for nearly two months.
                          • Shaky Jake
                            Ol' Poop
                            • Jan 2013
                            • 261
                            #718
                            Thanks for your concern. My job keeps me busy in the spring and fall. I've been working 13 hours a day 7 days a week for the last month and a half or so, away from home. I'll try to get things rolling again.
                            Kevin
                            Kevin
                            • BoschZEV
                              • Jul 2012
                              • 521
                              #719
                              My job keeps me busy in the spring and fall. I've been working 13 hours a day 7 days a week...
                              That still leaves you with 11 hours a day to work on the Indian.
                              • BoschZEV
                                • Jul 2012
                                • 521
                                #720
                                Don't forget to check your email because the motel reservation form arrived two hours ago. If you didn't get it, contact Lee Ann before all the 5 Star accommodations are booked.
