Powerplus or Bust, Eh?
  • Shaky Jake
    Ol' Poop
    • Jan 2013
    • 261
    #616
    Originally posted by panthersteve View Post
    I know it is a bit different but the '15 parts list has part number A5291 Intake valve lift hardened point, is it possible that the Powerplus had something similar and the bit you are questioning is that?
    Cheers
    Steve
    Well Steve, I think you are on to something there. I checked the 1916 parts book, it lists H522 Inlet Valve Lift Hardened Block, and H526 Inlet Valve Lift Hardened Block Rivet. These parts are absent from the later 1916-19-20-21-22 parts book, so they might not have been available as a separate part in those days, I suppose. The hard surface may have been worn off of the ones that I tested. It would be great if a new original Intake Lift still existed to look at, but I've never seen or heard of one.
    Kevin
    Kevin
    • Shaky Jake
      Ol' Poop
      • Jan 2013
      • 261
      #617
      I finally got the time to test Intake Cam Follower prototype #1 yesterday. I gained 21 degrees of duration and .076 inches of lift, at the valve, over the refurbished parts that were in there during the 2016 Cannonball. I feel like this is a success because I have proven that minor changes in the geometry of these parts can make significant changes in the valve action. During the test I could see a few minor tweaks that can be made to my Cam Follower design that will further improve things, so I will now revise my CAD drawing and take it back to the Machinist for another prototype. I could also see that I need to reverse engineer the Intake valve lift lever, because there is some interference between the refurbished one and the exhaust Cam Follower, that is limiting the lever's range of motion. I believe the tweaks on the Follower and the new lift lever will get me where I need to be as far as Intake valve lift and duration.
      Kevin
      Kevin
      • Shaky Jake
        Ol' Poop
        • Jan 2013
        • 261
        #618
        Intake Cam Follower prototype #2 has now been designed, drafted, and submitted to the Machinist. I made some small changes to the design, based on the test results. I should have something back around the time that I return from Davenport.
        In other news, I have decided that since there are no longer any kids in the house, I hereby claim the 22 x 24 detached garage next to the house as my new moto shed. I'm not giving up the basement shop, but it will become more the engine shop, and this will be more for working on rollers. It will also be handy when the tractor breaks down in winter, etc., by providing a warm place to work. Stage I was to empty it of all accumulated junk, err, I mean treasures, and strip it to the studs, and install additional outlets, including two 220v outlets for the welder:
        Stage two was the application of spray foam insulation:
        Drywall installation is currently in progress, then I will hang some LED lights. LED because my power panel is limited, so the plan is for all lighting to be off of one 20a breaker. After that, I will be looking for a good used wood stove to provide heat.
        Other than that, due to the fact that the Team Kelly's Heroes Cannonball Moto Van needs some paint and front brakes, I am thinking about a fund raiser. Would there be any interest in that? T-Shirts, or hats, or trinkets, something like that? Let me know what you think.
        Also, I got a tip from Joe Walano, aka The Guzzi Doc, on a guy in Chicago who repairs chipped cooling fins. I talked to the guy on the phone yesterday, and I'm going to hand off my cylinders to Joe at Davenport so he can drop them off for me. I'm also looking at Nikasil plating for my cylinders, rather than boring them any more.
        That's all for now, more to come.
        Kevin
        Kevin
        • painterdale
          • Oct 2013
          • 423
          #619
          Well, since no one else chimed in, Kevin, I'd be in for a kazoo or two!
          Dale
          • nuklhd
            • Jan 2009
            • 54
            #620
            Kevin, that will be a nice area to work in. I like the spray in insulation.
            I will watch the build thru the window and not bother anyone
            • Tom Lovejoy
              • Aug 2006
              • 951
              #621
              Hey Kevin if you are pleased with your cam followers your having made up. Any thought's on making a couple extra sets for others ? I am sure my followers are probably worn to, though I have not checked yet, just curious. Looking and thinking about things I can do to try and have a good performing engine. Enjoying your post, the work shop looks like it well be very nice. Wish I had some room like that.
              • Shaky Jake
                Ol' Poop
                • Jan 2013
                • 261
                #622
                Hi Tom. I'm thinking I'll run them on the 2018 Cannonball, and if they prove themselves I'll probably offer a few sets for sale, to try and recover part of the cost of developing them.
                Kevin
                Kevin
                • Tom Lovejoy
                  • Aug 2006
                  • 951
                  #623
                  very cool Kevin, please keep me in mind when the time comes
                  • Shaky Jake
                    Ol' Poop
                    • Jan 2013
                    • 261
                    #624
                    Of course. I did take my first prototype to Davenport with me, and showed it to some of my PowerPlus compadres. There was quite a bit of interest there also. It's something I could give back to the Antique Motocycle community.
                    Kevin
                    Kevin
                    • Shaky Jake
                      Ol' Poop
                      • Jan 2013
                      • 261
                      #625
                      A quick update on the intake valve cam follower and lift lever reverse engineering project. I'm on the second iteration of the follower prototype and the first iteration of the lift lever prototype. I'll probably have to do one more version of each before I finalize the designs. In this picture, the lift lever is closest to the camera, and the cam follower is behind it:
                      Here are my test results so far. The data was taken with the parts installed in the Cannonball engine, lift values measured at the valve, and the degree wheel mounted to the motor sprocket. Look at the far right column for the latest test. I'm very happy with the numbers. The duration is a little better than stock, and I've gained.090 inches of lift at the valve:
                      When the parts are in the engine, they work together like this. The cam lobe pushes on the cam follower here:
                      The cam follower pushes on the lift lever here:
                      And the lift lever then pushes on the tappet which pushes on the valve stem once the clearance is taken up:
                      What I've learned is that I can change the valve timing and lift by changing the configuration of that little bump on the top of the cam follower, that pushes on the lift lever. The little bump is essentially a little cam. So it follows that, as that little bump wears over the years, and/or gets reground to refurbish it, the valve timing and lift change, usually for the worse. I'm anxious to see the affect on performance with the new parts.
                      More to come...
                      Kevin
                      Kevin
                      • Tom Lovejoy
                        • Aug 2006
                        • 951
                        #626
                        very cool and interesting Kevin, good luck !
                        • Jim
                          • Sep 2001
                          • 789
                          #627
                          Amazing work!
                          Jim
                          AMCA #6520
                          • Shaky Jake
                            Ol' Poop
                            • Jan 2013
                            • 261
                            #628
                            Thanks guys. I'm having fun with this. It takes a ton of time though. Making a digital model of something that was originally manually machined out of a stamped or forged piece of steel has turned out to be challenging and time consuming. I have literally spent over a hundred hours in front of the computer to reverse engineer these two parts. I'm ready to wrap this part up so I can start taking my bottom end apart for a refresh. My cylinders are in Chicago getting the chipped fins repaired and new valve seats. I'm hoping to have it all come together in time for spring riding season.
                            My fall work season will wind down soon, so I should have time to catch this thread up to date before long.
                            Kevin
                            Kevin
                            • Shaky Jake
                              Ol' Poop
                              • Jan 2013
                              • 261
                              #629
                              Here are some pictures of the high tech tools that I'm using to "reverse engineer" the Indian valve train parts:
                              The radius gauges are a Davenport find.
                              Kevin
                              Kevin
                              • Shaky Jake
                                Ol' Poop
                                • Jan 2013
                                • 261
                                #630
                                Jason sent out an email to the Cannonball participants the other day. Not a lot to share yet, but they have laid out the route, and he did say that it would be 3875 Miles of Breathtaking, Scenic, Spectacular, and Challenging road ways.
                                Other than that, he shared this information:
                                September 8, 2018 Depart Portland, Maine
                                September 16, 2018 Arrive in Sturgis, SD
                                September 17, 2018 Rest Day Off, Sturgis, SD
                                September 23, 2018 Grand Finale Portland, OR
                                Kevin
                                Kevin
