101 light switch
  • 101 light switch
    has anyone removed this pin? screw? whatever it is , to remove the indicator so the plate can be painted? i am having no luck...thanks
    Yes, I disassembled one to swap an Indian branded plate for Henderson plate and re-used the internal mechanism. No surprises.
      How does the pin come out,do you press it out ? Thanks
        I used a size-matched drift and carefully pressed it out (and back in). Look at the pin to see if one end is distorted and, if so, have that side come out first.
          great, thanks i will give it a try
