101 light switch
  • cscott
    • Oct 2002
    • 451
    101 light switch
    has anyone removed this pin? screw? whatever it is , to remove the indicator so the plate can be painted? i am having no luck...thanks
  • C.Flint
    • Dec 2015
    • 49
    Yes, I disassembled one to swap an Indian branded plate for Henderson plate and re-used the internal mechanism. No surprises.
    • cscott
      • Oct 2002
      • 451
      How does the pin come out,do you press it out ? Thanks
      • C.Flint
        • Dec 2015
        • 49
        I used a size-matched drift and carefully pressed it out (and back in). Look at the pin to see if one end is distorted and, if so, have that side come out first.
        • cscott
          • Oct 2002
          • 451
          great, thanks i will give it a try
