46 front brake drum lever
  • 46 front brake drum lever
    I've got a 46 chief with the spring loaded hollow bolt thingy at the front brake lever on the drum plate.
    Do I use a standard cable and how does the cable attach to it? I have not seen one of these completely assembled.
    Also is there a proper way to adjust it?
    Sorry for the "technical description"
    Thanks,
    Doug
    '46 brake lever...
    Hope these photos help you out...Bones
      lever
      Beautiful picture! The cable is different that the 47 and up cables. This inner cable is about .090" thick, while the 47-53 is about .062"
        lever
        Hit the send by mistake. Here's a great sheet Michael Breeding made years ago
        Bob
          lever
          Here's a bigger version, the first is too small!
            thanks Bob, but I had to stand on my head to view it
            Kevin Valentine 13
            EX-Chief Judge
              Thanks guys. It's much clearer now.
              Do the ends have to be crimped or soldered?
              Where's the best place to get an accurate repo of the cable?
              Doug
                '46 brake cable...
                Soldered. Check this link.http://www.antiquemotorcycle.org/bbo...ad.php?t=15101
                Check with Brian Stearns at Advanced Welding in CA. Haven't spoke with him for a long time, don't know if the numbers are good. (650)967-5583 (650)967-6632....
                Also check with Jerry Greer Engineering or Starklite
                  Perfect. Thanks.
                  Doug
                    solder
                    I made a bunch of those 396001 ends years ago. To solder them, I wound up using a "soft Silver Solder", #38115. It's a plastic, round package with liquid flux and a long piece of silver solder. Supposedly it's a lot stronger than lead/tin only solder and it holds great. I did mine over 10 years ago, still there!
                    Bob
