46 front brake drum lever
  • dcanaday
    • Mar 2010
    • 8
    I've got a 46 chief with the spring loaded hollow bolt thingy at the front brake lever on the drum plate.
    Do I use a standard cable and how does the cable attach to it? I have not seen one of these completely assembled.
    Also is there a proper way to adjust it?
    Sorry for the "technical description"
    Doug
  • BONES47FL
    • Apr 2009
    • 73
    '46 brake lever...
    Hope these photos help you out...Bones
    • cdf6333
      • Nov 2008
      • 273
      lever
      Beautiful picture! The cable is different that the 47 and up cables. This inner cable is about .090" thick, while the 47-53 is about .062"
      • cdf6333
        • Nov 2008
        • 273
        lever
        Hit the send by mistake. Here's a great sheet Michael Breeding made years ago
        Bob
        • cdf6333
          • Nov 2008
          • 273
          lever
          Here's a bigger version, the first is too small!
          • kval
            • Jul 2001
            • 508
            thanks Bob, but I had to stand on my head to view it
            Kevin Valentine 13
            EX-Chief Judge
            • dcanaday
              • Mar 2010
              • 8
              Thanks guys. It's much clearer now.
              Do the ends have to be crimped or soldered?
              Where's the best place to get an accurate repo of the cable?
              Doug
              • BONES47FL
                • Apr 2009
                • 73
                '46 brake cable...
                Soldered. Check this link.http://www.antiquemotorcycle.org/bbo...ad.php?t=15101
                Check with Brian Stearns at Advanced Welding in CA. Haven't spoke with him for a long time, don't know if the numbers are good. (650)967-5583 (650)967-6632....
                Also check with Jerry Greer Engineering or Starklite
                • dcanaday
                  • Mar 2010
                  • 8
                  Perfect. Thanks.
                  Doug
                  • cdf6333
                    • Nov 2008
                    • 273
                    solder
                    I made a bunch of those 396001 ends years ago. To solder them, I wound up using a "soft Silver Solder", #38115. It's a plastic, round package with liquid flux and a long piece of silver solder. Supposedly it's a lot stronger than lead/tin only solder and it holds great. I did mine over 10 years ago, still there!
                    Bob
