1941 Chief tank badge placement?
  • JTR249
    • Jul 2019
    • 768
    I know this is from a year ago, but I recently bought a 1941 Chief frame (771) and am using it to collect parts for a build. Definitely a civilian restoration eventually, but I am using an EU rear fender and front fender. One thing that is confusing at this point is finding the correct fuel tanks. Can someone post a mounted mock-up view of what the correct 40-45 tanks looked like?
    Here are a couple I have found looking online, but I don't know if they are correct.
    1941 to 1945 Indian Chief Fuel Tanks 1.jpg 1947 Chief Tanks.jpg Just for contrast, I have posted what one seller calls 1947 Chief tanks (gray) and if you compare the instrument panel cut-outs, they are different. The 47 is shorter and has two curves whereas the one identified as 40-45 has one curve and is longer. You can visibly see the curve continues clearly below the reserve fuel channel. I would appreciate it if someone could post the same view of a verified set of 41-45 Chief tanks.
    Thanks.
    -JR
      • 1676
      JR, pretty sure the tanks with the rectangular hole go to a Chief with a generator charging light, '48 and up.
      BTW, Kiwi has welded tanks available now, probably more money but worth it.
      • JTR249
        • Jul 2019
        • 768
        Ok, but why are the insets different if they are the same? Different years?
        -JR
          • 1676
          -JR
          ...the same? Not certain what you mean, but consider two different speedometers were used post '47 and that could explain why there are two different openings.
          • JTR249
            • Jul 2019
            • 768
            That makes sense.
            Ok, so can you or someone else show me the same photo of 1941-1945 Chief tanks?
            That's what I need to see. Do they look the same?
            -JR
              • 1676
              ...this past conversation might help a little. I've always thought '41 thru '47 tanks were the same
              • Green Indian
                • Apr 2014
                • 303
                AMCA # 3233
                • JTR249
                  • Jul 2019
                  • 768
                  Thanks, Damon. I appreciate the photo.
                  You too, Harry. I checked out the link and that was exactly what I needed.
                  I have the same issue Roadhome had but my sides are switched.
                  -JR
