Schebler DLX130 float level 1940 Chief
  • 39ChiefBonnie
    • Feb 2014
    • 48
    #31
    Ok well I will try inking and see what happens. Thanks
      • 8248
      #32
      A freshly dressed point, Matt,...
      Usually gives the best reading.
      PS: Sometimes you must grind them from scratch; Idle needle shown...
      • 39ChiefBonnie
        • Feb 2014
        • 48
        #33
        Nice equipment!! What angle is the grinding stone/needle? Thanks
          • 8248
          #34
          Its an ancient flat-belt Van Dorn valve grinder, Matt,..
          Gifted to me by Ronnie Kingsley from his father Richard Kingsley, both longtime Chief Blackhawk members, and both sadly missed.
          Highspeed angles varied:
          HX 30º
          GX 27º - 30º
          DLX 30º
          SV HD 30º
          OHV HD 45º
          M74B 22º
          M53, 53A1, M74, and probably others have stepped HS needles, and the -53 series has stepped LS needles.
          My fossil record for lowspeeds varies greatly, and should only be measured geometrically.
          (The Van Dorn is still set,.. but its way way off the scale!)
          • 39ChiefBonnie
            • Feb 2014
            • 48
            #35
            Great info and the photos really add to the understanding. Thank you.
