primary chain replacement
  • Dschurm
    • Nov 2021
    • 1
    Can anyone tell me what's involved in replacing the primary chain on a 48 chief . Specifically how to remove the rear sprocket ? Thanks.
    • 965
    To remove the cluctch basket you have to remove the trans top,nut on clutch basket inside the trans,kick start gear,and gen. drive pulley and key.
    Then the primary chain and sprockets ,clutch and mainshaft can be slid out together.
      • 8238
      Special tools make much easier, Dshurm!
      The wrench it the important one,...
      .....Cotten
        • 1675
        In the AMCA virtual library is the Overhaul and Repair Manual, gives a pretty good description of the process
        • Dschurm
          • Nov 2021
          • 1
          Hi , Thanks for the info . It's more complicated than I thought . I also think I have to much end play in the main shaft . I guess I have to figure that out too. Thanks guys.
          • PaulCDF
            • Aug 2019
            • 1429
            You might find Pisten-Bully's post in this Chief forum of interest: in-frame gearbox rebuild 07-11-2021
            Good Luck keep us posted.
