I took it all apart and cleaned it with carb cleaner and compressed air. The only issue I could find was that the float was set about 1/8' too high, so I corrected that and put it back together. I can't think of anything else, so I'll start it up and see what I get.
Carb adjustment question
Well, Jeff,..Originally posted by Lipdog View PostI don’t know exactly what it’s made of, but it’s black hard, hollow plastic, if that helps. Thanks,
Jeff
The carb was designed to use a three gram float.
What's it weigh?
(If the pivotnut is molded-in, its not only a boatanchor to begin with, but prone to swelling.)
PS: An example is shown on the left in the attachment; On the right is a float of proper buoyancy, but still swollen by fuels unknown.Attached FilesLast edited by T. Cotten; 09-22-2019, 12:39 PM.AMCA #776
It weighs about 8g (see photo). I'm ordering some parts, which one should I specify to replace it with? I'm going to get the LS needle that's the proper length too. Thanks!
Demand a DURABLE, Jeff!Originally posted by Lipdog View PostIt weighs about 8g (see photo). I'm ordering some parts, which one should I specify to replace it with? I'm going to get the LS needle that's the proper length too. Thanks!
I would replace the rubber-tipped floatvalve while you're at it.
Although yours is the somewhat better Starklight offering.
(Unfortunately, Gary's float ain't. Why is it the same shape and size, and weight, as a made-in-India brass boatanchor?)
When you inspected your idle bleeds, did the plug have a "tit" on it?
(Not that we know why...)
....CottenAttached FilesLast edited by T. Cotten; 09-22-2019, 02:06 PM.AMCA #776
It was supposed to look like this, Jeff!
Don't know why.
