Carb adjustment question
    I took it all apart and cleaned it with carb cleaner and compressed air. The only issue I could find was that the float was set about 1/8' too high, so I corrected that and put it back together. I can't think of anything else, so I'll start it up and see what I get.
      What kind of float was it, Jeff?
        I don’t know exactly what it’s made of, but it’s black hard, hollow plastic, if that helps. Thanks,
        Jeff
          Jeff
          Well, Jeff,..
          The carb was designed to use a three gram float.
          What's it weigh?
          (If the pivotnut is molded-in, its not only a boatanchor to begin with, but prone to swelling.)
          PS: An example is shown on the left in the attachment; On the right is a float of proper buoyancy, but still swollen by fuels unknown.
          • #20
            It weighs about 8g (see photo). I'm ordering some parts, which one should I specify to replace it with? I'm going to get the LS needle that's the proper length too. Thanks!
            • #21
              Demand a DURABLE, Jeff!
              I would replace the rubber-tipped floatvalve while you're at it.
              Although yours is the somewhat better Starklight offering.
              (Unfortunately, Gary's float ain't. Why is it the same shape and size, and weight, as a made-in-India brass boatanchor?)
              When you inspected your idle bleeds, did the plug have a "tit" on it?
              (Not that we know why...)
              • #22
                Idle plugs are flat. Thanks
                • #23
                  It was supposed to look like this, Jeff!
                  Don't know why.
