What type tubing for oil lines?
  • mark59
    Mark
    • Dec 2010
    • 32
    i have been using cunifer brake lines for many years, a nickle copper alloy tubing, easily bendable and used on many high end autos. i would think larger diameters would be available.
    • larrymgibson
      • Aug 2015
      • 70
      I finally got my Indian running. I looked in the tank with a borescope and confirmed the oil was being returned. Here is a photo of the copper lines. It seems to miss everything and flows oil.IMG_4210.jpg
      • tomfiii
        • Jun 2007
        • 314
        An intermediate support should be added if you haven't already done so.
        • Green Indian
          • Apr 2014
          • 303
          Larry,
          I've never seen a Chief oil tank and line run in that manner, was the bike always like that? Are there issues with the oil tank/gas tank leaking that required the re-routing of the tank and lines?
          AMCA # 3233
          • RichO
            • Dec 2001
            • 903
            I would caution against using modern compression fitting with copper lines (not the same as soldered on ferrules) as they compression the line and make a fracture line that will deepen from vibration and cause failure. I sometimes put a loop in them to give the line a place to flex and cancel out vibration. Just sayin'.
            DrSprocket
              • 6027
              I agree with RichO. I only use copper lines if I make the ferrule that is soldered to the copper line, and match the angle of the fitting. That is the way all manufacturers who used copper lines did it, and they knew what they were doing.
              • larrymgibson
                • Aug 2015
                • 70
                The re-routing was to increase the fuel capacity. My dad and I rode a couple of trips from Indiana to Colorado and beyond. He eventually put over 100,000 miles on this Indian. In 1955-1960, fuel stations were few and far between in the mountains. He was a light aircraft mechanic and liked to make things better. The idea came from Harleys which have similar oil tank locations. This added almost another gallon of fuel capacity. He also fabricated a tank which fit between the two tanks. He used it on several trips out west. I just decided to retain the modifications that were made by my dad.
                • larrymgibson
                  • Aug 2015
                  • 70
                  Instead of replying to the thread, I replied to the last comment. Not sure how the notification works. I'll copy here.
                  • larrymgibson
                    • Aug 2015
                    • 70
                    Do you mean a support in the middle of the run to lessen the vibration on the fittings?
                    • Green Indian
                      • Apr 2014
                      • 303
                      Thanks for that explanation, great history on that Chief too, your Dad must have been a great guys to wrench with and learn from. You are very lucky to have had a Dad like that.
                      AMCA # 3233
                      • Bubbalowe
                        • May 2018
                        • 80
                        There is patented system Swagelok which uses an extra ferrule and eliminates need for solder.
                          • 6027
                          #27
                          I made 9 of these Merkel furrules, and nuts just today. I always make my own, and copy original dimensions. I match the angle of the ferrule to the angle of the mating fitting and have never had a leak. There are many modern devices, and materials that are superior to those from 100 years ago, but the challenge, and fun of old bikes is to explore the world of yesterday. I think using modern technology on old bikes can be appropriate inside the motor, trans, and other places that don't show; but you have to be careful that you don't loose the whole point of messing around with ancient motorcycles.
                          • larrymgibson
                            • Aug 2015
                            • 70
                            #28
                            Yes I was.
                            • larrymgibson
                              • Aug 2015
                              • 70
                              #29
                              Yes I was.
