Tires for 1970 CH
  • billpedalino
    • Mar 2005
    • 1096
    Originally posted by Spag View Post
    Bill,
    My 1970 restored Sportster. Rear tire: Continental 4.00x18. Front tire: Continental 3,25x19. If you want a close to stock look on your restoration.
    Richard
    Spag,
    First off, my compliments on such a beautiful restoration. I've restored a 1947 FL (99 points), a 1953 FLE, and a 1964 XLCH, so I can appreciate the work involved in your 1970 XLH. From a parts acquisition standpoint, the CH was by far the most difficult to find parts for. My '70 won't be as factory-original as yours, but close. I plan to have it judged as a Period-Modified machine with the minor modifications that I made as a kid so many years ago. This includes a motor that I stroked back then and just de-stroked - I have no business running around on a stroker Sportster these days! I also converted it to electric/kick back then, which was a popular thing. It's now kick-only. It is a very nostalgic bike for me, so it truly is 'period-modified'.
    The tires certainly do look quite similar to the Sport Rib and All-Traction originals. The problem is finding these tires. When I was in the business, I used to be able to have a substantial automotive tire house special order motorcycle tires, but apparently that's not allowed any more. Can you recommend a source for these Continental tires?
    Thanks...
    Bill Pedalino
    Huntington, New York
    AMCA 6755
    • Spag
      • Dec 2001
      • 186
      Biil
      A brief Google search did not reveal any supplier of appropriate Continental tires for a 1970 Sportster like the ones on my bike. The front Continental is available from several sources in Europe. Not sure why Continentals for vintage bikes are no longer being sold in the USA.
      Richard
      Richard Spagnolli
      AMCA #6153
      • billpedalino
        • Mar 2005
        • 1096
        Biil
        Richard
        Yes, I'm finding the same information. And they're very expensive!
        Bill Pedalino
        AMCA 6755
        • joe fxs fxr
          • Dec 2020
          • 701
          Originally posted by Buster View Post
          Sportsterpedia says 1970-78 have CM rims. I know many put regular tires on them. I wouldn’t, I would lace in a modern rim.
          OK, but where do I get a modern 18" rim?
          AMCA #41287
          1971 Sprint SS350 project
          1972 FX Boattail Night Train
          1972 Sportster project
          1973 HD Golf Cart project
          1989 Springer Softail project
          2020 Heritage Classic 114
          • billpedalino
            • Mar 2005
            • 1096
            I'm using my original aluminum rims. I understand the Harley Bulletin, but in the mid 1960's through the 80's we mounted tires of all types on these rims without any adverse affects. In fact, I ran Goodyear Eagle. low profile tires on this particular bike for many years and, as a stroker, I can assure you that I wasn't easy on it (I was young and dumb). AND... I didn't use the locking rear rim-to-tire sheet metal screws.
            I certainly don't profess to know more than the Engineers who wrote the service bulletin, and I'm not advising anyone to violate the bulletin's advice. But for me, it's an acceptable risk that I'm willing to accept..
            Bill Pedalino
            AMCA 6755
            • billpedalino
              • Mar 2005
              • 1096
              I received the Continental tires today and they look fairly similar to the Goodyear tires. They were expensive, and (I assume) came from a European source, so they took awhile to receive. But as seen in Sprag's photos above, they should look equally as nice on my Period-Modified CH.
              Thanks to all for your input.
              Bill Pedalino
              AMCA 6755
              • billpedalino
                • Mar 2005
                • 1096
                [QUOTE=billpedalino;n328737]I received the Continental tires today and they look fairly similar to the Goodyear tires. They were expensive, and (I assume) came from a European source, so they took awhile to receive. But as seen in Sprag's photos above, they should look equally as nice on my Period-Modified CH.
                Thanks to all for your input.[/QUOTE
                I mounted the Continental tires and they look fine. However, Given all of the above, It's probably smart to locate the functionally correct pair of Goodyear A-T tires. I started looking for Eagle A-T tires on the web with no luck thus far. I'm surprised, as these are American-made and I thought they would be more plentiful than the Continentals. Does anyone have as source for Eagle A-T tires? If not, is there another tire that would correctly bead to the aluminum rims?
                Thanks ....
                Bill Pedalino
                AMCA 6755
