Tires for 1970 CH
  • billpedalino
    • Mar 2005
    • 1096
    Tires for 1970 CH
    I'm assembling my '70 CH for future judging as a 'Period Modified' machine, with almost everything as factory-installed, but with a few changes I made to the bike when I bought the bike when I was young (around 1973), and that I'm keeping for nostalgic reasons.
    One sticking point is tires. The bike cam with an 18" Goodyear All-Traction on the rear and, if memory serves, a 19" Goodyear Sport-Rib on the front. I've been trying to find useable All-Traction tires for years without luck and, while I haven't looked for the Sport Rib tires yet, I'm guessing that they're scarce as well.
    Can anyone recommend replacement tires that look similar to the original ones?
    Thank You...
    Bill Pedalino
    Huntington, New York
    AMCA 6755
  • otis71
    • Jul 2015
    • 597
    Duro makes a front tire that looks similar to a sport rib and don’t cost a bundle, only problem is they’re not tapered bead and that’s a safety concern if still running tapered rims. I don’t think anyone ever made tapered bead tires other than Goodyear. The motor company put out a service bulletin back in the day when supplies ran out for dealers not to mount tires on tapered rims. The solution in the bulletin was to lace new standard rims.
    • joe fxs fxr
      • Dec 2020
      • 701
      Tapered beads? Never heard that term before (live and learn). What years had them, and when did they change to standard rims? Thanks
      AMCA #41287
      1971 Sprint SS350 project
      1972 FX Boattail Night Train
      1972 Sportster project
      1973 HD Golf Cart project
      1989 Springer Softail project
      2020 Heritage Classic 114
      • billpedalino
        • Mar 2005
        • 1096
        OBS and Joe,
        I agree and appreciate both responses, but I'm also not familiar with the term 'Taper Rim' Maybe it refers to what was then called 'Safety Beads'? Anyway, I'm running the OEM aluminum rims. Would that be a concern for the tires in question?
        Bill Pedalino
        AMCA 6755
        • Spag
          • Dec 2001
          • 186
          Bill,
          My 1970 restored Sportster. Rear tire: Continental 4.00x18. Front tire: Continental 3,25x19. If you want a close to stock look on your restoration.
          Richard
          This gallery has 3 photos.
          Richard Spagnolli
          AMCA #6153
            • 4789
            Originally posted by billpedalino View Post
            OBS and Joe,
            Safety bead rims and taper bead rims are not the same. H-D did taper bead to have a proprietary tire and tire supplier, it didn't work out so they quit for liability reasons.
              • 4789
              Sorry Bill, thought I could help. After looking through a pile of Dunlop K-70s and Pirelli MT53s I found the one All Traction...and it is a 4.00-19. So no joy!
              • joe fxs fxr
                • Dec 2020
                • 701
                Were there particular years for the taper bead rims?
                AMCA #41287
                • Speeding Big Twin
                  • Mar 2010
                  • 433
                  Service Bulletin 597.
                  Eric
                  • billpedalino
                    • Mar 2005
                    • 1096
                    Unfortunately, I had the same luck. I have an 18" All Traction tire that's in almost perfect condition, except that someone very neatly hacksawed straight through 50% the tire it at one location! I know that we did a lot of dumb things back in the 1970's, when we were young and dumb. But the reason why somebody would do that to a perfectly good, almost new tire remains a mystery to me. But I save it because it's such a beautiful example (except fort the cut).
                    Thank you so much for looking.....
                    Bill Pedalino
                    AMCA 6755
                    • joe fxs fxr
                      • Dec 2020
                      • 701
                      Eric
                      Ah it's a 1970 only issue. My 72 should use normal tires, right? Same for my 72 FX. Thanks!
                      AMCA #41287
                      • otis71
                        • Jul 2015
                        • 597
                        I believe they ran tapered beads from 1970-76. Definitely more than a year or two. The tires are marked with a T after the size numbers on the sidewall.
                        • Buster
                          • 385
                          I believe 1970-76 is correct, my basket 1974 has them. Lot of info on these in Sportsterpedia web page. Going to replace both rims to standard type rims.
                          • Speeding Big Twin
                            • Mar 2010
                            • 433
                            Joe, sorry if I created confusion about how long those rims were used for.
                            Eric
                            • Buster
                              • 385
                              Sportsterpedia says 1970-78 have CM rims. I know many put regular tires on them. I wouldn’t, I would lace in a modern rim.
