starter replay
  • rbenash
    • Jul 2001
    • 643
    Some photos - first two are as originally mounted before teardown, third is with the reapined battery box during assembly with the original re-cad counter sunk screw/nuts showing placement.
    Ray
    AMCA #7140
    • rbenash
      • Jul 2001
      • 643
      Originally posted by rbenash View Post
      It was installed to the battery box, but had a specific bracket and hardware. Tight fit for sure. In '66 and later they even had an accessory cover made for it that hung below the battery box. More holes My NOS starter relay kit is up at the shop doing my restoration. Going to see if I can get them to fax me a copy of the installation docs, will scan and post.
      Don't have the shop bulletin. I'l double check to make sure I don't have a pdf laying around somewhere. I'm betting that Chris has one though
      Folks - just to update on this post above. I just noticed that Mike was talking about the circuit breaker mod In my response I was still talking about the starter relay. The circuit breaker had a mount attached to/integral to it. Sorry for any confusion.
      Ray
      AMCA #7140
      • 65eglide
        • Jul 2007
        • 62
        I notice you have a grounding strap on the bottom starter stud, is that stock ?
        is the other side mounted to the frame?
        • Underdoggie
          • Mar 2009
          • 100
          No, I dont think that is right. The judges at Davenport even gave me a deduction for having the extra grounding strap. I added it with the relay just for good measure. Im going to re route it somehow this year.
          Underdoggie
          John Underwood
          AMCA#14400
          Central Illinois
          • 65eglide
            • Jul 2007
            • 62
            Any idea on how many grounding straps there are ?
            I don't have any on mine and can't find any reference in the service manual or wiring diagrams on where they would be
              Here’s a suggestion. I know it’s not oem but it works well. Over the years my buddies have come to me asking what they can do about this piece of it relay. I installed a miniature plug in relay for them. It measures 1” square and can be mounted anywhere. They fit in the headlight cowl with no problem. One of these little puppies can handle about ten amps and there water tight. Ya mount the base, wire and plug in the relay. Ya throw and extra in your tool kit and your good to go. When it dies you just pull off the relay and plug the new one in. No wiring or screws to touch. Almost like plug and play on the computer. You can get them from any industrial wholesaler dirt cheap. Bob L
              • rbenash
                • Jul 2001
                • 643
                I only found one on mine. Starter to trans stud. 99% Sure that's stock.
                Ray
                AMCA #7140
                • rbenash
                  • Jul 2001
                  • 643
                  I would do this if I couldn't find an original, not an inline fuse like I've seen some folks do. Or just use a 30 amp self resetting breaker.
                  Ray
                  AMCA #7140
                    Lets keep in mind that all your doing is triggering the starter solenod. A control circuit does not require a 30 amp fuse. 5 amp would just be danndy. I wouldn't even conceive of taking a motorcycle and spending the money and energy to restore it and not hiding a fuse some where off the battery.This is just common sense. I know the later bikes had the circuit breakers but I never trusted them. Just my two cents. Bob L
                    • rbenash
                      • Jul 2001
                      • 643
                      Good points.
                      Ray
                      AMCA #7140
                      • Underdoggie
                        • Mar 2009
                        • 100
                        I have that same one your talking about, and that one was always on the bike. I dont know for the life of me why I added that extra one with the relay shown in my picture so that makes one. Also, the regulator needs to be grounded. So that makes two right?
                        I'm takin' that extra one off, looking at it now, it doesnt make any sense. I must have been drinking that day.
                        Underdoggie
                        John Underwood
                        AMCA#14400
                        Central Illinois
                        • portagepan
                          • Feb 2006
                          • 580
                          #27
                          65 Harley Breaker
                          We had a long discussion on this on 10-6-06. I don't see the pictures that were attached to the e mails. Anybody know why?
                          Mike
                          • rbenash
                            • Jul 2001
                            • 643
                            #28
                            Mike
                            Can't answer that Mike but here's some circuit breaker stuff that's been going on lately:
                            http://www.antiquemotorcycle.org/bbo...1&d=1228626896
                            And:
                            http://www.antiquemotorcycle.org/bbo...ircuit+breaker
                            Or here:
                            http://www.antiquemotorcycle.org/bbo...ad.php?t=14758
                            Still a popular topic
                            Ray
                            AMCA #7140
