Alemite extension on brake crossover tube
  • Alemite extension on brake crossover tube
    Should I use an extension (see photo attached) or not?
    See photo attached.
    If I use it, the fitting is too close to the oil filter return line.
    Chris H. already provided me with a factory photo that definitely shows it to be a straight fitting. Thanks, Chris.
    But the extension/adapter causes it to be a little long. Going for those last few points, so this matters greatly to me.
    Oh, for a '55 FLH.
    Thanks,
    Wayne
    see your post at CAI
    Jeff Bowles
    Arkansas
    Membership # 14023
    1957 Sportster
      The post at CAI answered the straight vs the 67 1/2 degree question but not the extension question. Extension or no extension?
      BTW, the AMCA website was down most of the day. Or is that old news?
      Thanks,
      Wayne
        old news it was down all day yesterday
        Jeff Bowles
        Arkansas
        Membership # 14023
        1957 Sportster
          And the day before that.
          As for the extension, thee factory photo shows a straight fitting with no extension.
            man, oh man your eyes must be good! I couldn't see, no matter how much I blew it up.
            Thank you kindly.
            Wayne
              Thank you kindly.
              Wayne
              How about this?
                THAT I can see! When I save any of your pics to my PC and then try to blow them up, they get fuzzy/blurred.
                This "no extension required" makes sense as now the grease gun can fit onto the fitting. Thanks, Chris.
                Wayne
                  See photo attached.
                  Oh, for a '55 FLH.
                  Thanks,
                  Wayne
                  [ATTACH]4114[/ATTACH]
                  Here's one with an extension. My '48 frame had one too
                    I never under stood why the factory didn't use a 67.5 degree grease fitting that would have made so easy to get to the fitting. I think the book even called for the angle one. Bob L
                    AMCA #3149
                      See photo attached.
                      Oh, for a '55 FLH.
                      Thanks,
                      Wayne
                      Here's another
                        If you are using a reproduction oil line chances are good it is not correct.
                          I had the same thought.
                            In the case of the oil filter line I'd use the angle one. If a judge calles ya on it. Hand the genuine HD parts book. Bob L
                            AMCA #3149
                              What if the judge hands you this photo?
