Alemite extension on brake crossover tube
  • felthamw
    can't re-Member
    • Aug 2008
    • 92
    Should I use an extension (see photo attached) or not?
    See photo attached.
    If I use it, the fitting is too close to the oil filter return line.
    Chris H. already provided me with a factory photo that definitely shows it to be a straight fitting. Thanks, Chris.
    But the extension/adapter causes it to be a little long. Going for those last few points, so this matters greatly to me.
    Oh, for a '55 FLH.
    Wayne
  • jmanjeff
    • Apr 2008
    • 252
    see your post at CAI
    Jeff Bowles
    Arkansas
    Membership # 14023
    1957 Sportster
    • felthamw
      can't re-Member
      • Aug 2008
      • 92
      The post at CAI answered the straight vs the 67 1/2 degree question but not the extension question. Extension or no extension?
      BTW, the AMCA website was down most of the day. Or is that old news?
      Wayne
      • jmanjeff
        • Apr 2008
        • 252
        old news it was down all day yesterday
        Jeff Bowles
        Arkansas
        Membership # 14023
        1957 Sportster
          And the day before that.
          As for the extension, thee factory photo shows a straight fitting with no extension.
          • felthamw
            can't re-Member
            • Aug 2008
            • 92
            man, oh man your eyes must be good! I couldn't see, no matter how much I blew it up.
            Thank you kindly.
            Wayne
              Thank you kindly.
              Wayne
              How about this?
              • felthamw
                can't re-Member
                • Aug 2008
                • 92
                THAT I can see! When I save any of your pics to my PC and then try to blow them up, they get fuzzy/blurred.
                This "no extension required" makes sense as now the grease gun can fit onto the fitting. Thanks, Chris.
                Wayne
                • 48hdbob1
                  • Nov 2009
                  • 111
                  See photo attached.
                  Oh, for a '55 FLH.
                  Wayne
                  [ATTACH]4114[/ATTACH]
                  Here's one with an extension. My '48 frame had one too
                    I never under stood why the factory didn't use a 67.5 degree grease fitting that would have made so easy to get to the fitting. I think the book even called for the angle one. Bob L
                    • 48hdbob1
                      • Nov 2009
                      • 111
                      See photo attached.
                      Oh, for a '55 FLH.
                      Wayne
                      Here's another
                        If you are using a reproduction oil line chances are good it is not correct.
                        • 48hdbob1
                          • Nov 2009
                          • 111
                          I had the same thought.
                            In the case of the oil filter line I'd use the angle one. If a judge calles ya on it. Hand the genuine HD parts book. Bob L
                              What if the judge hands you this photo?
