thread size or sizes
  • Glenn
    Member to Remember
    • May 2007
    • 403
    is there anywhere listed or does anyone know the thread size of the grease fitting on a 50 pan for the seat and the brake shaft.
    as a matter of fact is there anywhere listed the exact size of bolts that are for that year bike?
    thanks
    Moose
    aka Glenn
    • 6037
    Glenn, I come up with 5/16-32 for the zerk fitting thread pitch. You can get odd ball taps and dies from MSC or McMaster Carr Industrial supply. I use the "Spare Parts" book for all of my bolt length and sizes. That's the bright orange book.
    • portagepan
      • Feb 2006
      • 580
      I think Colony has the grease fittings, 4 to a card.
      Mike
      • Glenn
        Member to Remember
        • May 2007
        • 403
        thanks
        I ordered the spare parts book from antique motorcycle
        I'll order the tap
        Moose
        aka Glenn
          Glenn. If ya need a grease fitting. I'll drop one in the mail to you. Bob
          • Glenn
            Member to Remember
            • May 2007
            • 403
            both are not in the frame and I have to tap them out because they have a lot of paint in them
            Moose
            aka Glenn
            • portagepan
              • Feb 2006
              • 580
              Be careful. There isn't much there. It is a common size, so you can tap them. I have, but on the t-bar there are only about 3 threads. Cleaning is one of those things you just have to keep at on old machines. Soaking, brushing, air pressure, etc.
              Mike
