V twin heads
  • ldfly112
    • Sep 2017
    • 146
    V twin heads
    I have just purchased a set of 1955 to 1962 V twin heads going to install them on my stock 1961 FLH any suggestions if you have tried them and what spark plug works best for them
    • 2034
    I've sold a few sets to a local engine builder & he has had great luck with them. As far as plugs, the ignition used is important to what plugs are used.
    • ldfly112
      • Sep 2017
      • 146
      the ignition is eboyond 2000 electronic
      • dukekleman
        • Jul 2022
        • 596
        I've seen quite a few sets out in service. I have not seen any issues with any of them yet.
        I'll add this...
        1) I wish they could be purchased "without" the valve seats machined.
        2) I wish the offered them with OEM Intake valve sizes.
        However, I am grateful they offer what they do. It's a nice option for some people.
        Duke Kleman
          • 2034
          I think Ebeyond is made to use stock coils & wires so my guess is it works best with non resistor plugs. Most people have a brand that they like. Stating a brand will bring out likes & hates. Cantact Ed & ask him.
          • PanheadFred1
            • Dec 2019
            • 75
            I have a set that use shovelhead cylinders and accept shovelhead intake and exhaust. They've only been on less than a year, but, so far so good.
            • Saddletramp
              New Old Member
              • Aug 2011
              • 129
              Why can't I start a new thread. With pictures of a 30 VL with side hack and a 26 B model? This website?
              • Saddletramp
                New Old Member
                • Aug 2011
                • 129
                • Saddletramp
                  New Old Member
                  • Aug 2011
                  • 129
                  • ldfly112
                    • Sep 2017
                    • 146
                    the electronic ignition says it works best with resistor spark plugs any one have any idea what resistor plug I should try first Thanks if you can help
                    • jstraker
                      • Oct 2013
                      • 59
                      I bought a 1965 panshovel a few years back with an eBeyond installed. I run non-resistor plugs in it and it works just fine. I know some people don't like Champions, but I have been running J12YC with no spark issues. Gapped to 0.028 with suppression wires.
                        • 2034
                        Champion RJ12YC is the resistor version. Make sure your heads are for short reach plugs.
                        • dukekleman
                          • Jul 2022
                          • 596
                          The V-Twin brand replacement cylinder heads for Panheads require the long reach spark plugs, the same as a Evolution series Harley Davidson engines use.
                          Hope this helps,
                          Duke Kleman
                          • ldfly112
                            • Sep 2017
                            • 146
                            The V twin heads that I purchased require long reach plugs RJ12YC are short wont work
                              • 2034
                              Champion long reach Shovelhead/Evo resistor plugs are RN12YC
